The TP-Link Archer C7 is an AC1750 dual-band gigabit wireless router.
As of 2021, there have been five hardware revisions, marked on the bottom label as “Ver X.0”.
Straighten each antenna by unfolding it at the hinge.
Hold each antenna by the knurled (ribbed) base and unscrew it from the body of the router. Remove all three antennas.
Remove the 4 screws that secure the top cover of the router to the base.
Use a pry tool to pull the edge of the top cover outward from the base at each joint, until it unlatches. There are 9 joints in total.
Remove the top cover.
For easier opening begin case cover removal with outer corners at back side where connectors and sockets are. Put prying tool in thin gap between cover and bottom plate in one corner and pry cover open. Then do that in opposite side. Continue prying around cover until all cover at front, left and right sides is separated from bottom plate.
In end pry open cover in area between middle antenna connector and blue WAN socket. Be careful though - there is only one thin plastic pin inside. If it doesn’t open easy, do not apply force to it. Cover is now partially open at front side where pin is accessible with long flat screwdriver or other flat metallic tool. Pull pin to your side which will free the cover completely.
I got a question, how do I pry it without breaking the plastic?
Use Opener tool. In absence of it payment card with sharpened edge or disposable plastic knife will work as well. However be careful to avoid breaking plastic pins on inside edges of router case.
Screwdriver?
It’s a little tricky, but just using a pry tool (actually finger nails and credit card would probably work), you can start to work it off starting in the front. My AC1750 just stopped working. No wireless. No networking. The reset button generates no change to the LEDs. Seems to have just turned into a dumb hub. I opened it up - but just couldn’t find anything suspicious. Frustrating - as all I did was put away in a closet for two years. It was working before.
This appears to be an Archer C7 V2 or similar shown in this writeup. I have both a C7 V2 and a C7 V5 and they are quite different. The V2 has 3 Internal 2.4 Ghz antennas, and the removable external antennas are for 5 Ghz only. If you plan on using this for some long range 2.4 Ghz with aftermarket antennas, this will not work without substantial modification. The V5 does not have removable antennas, but the external fixed antennas are dual band 2.4 / 5 Ghz. The circuit board is also considerably different. The V2 has a separate add-on card for the 5 Ghz radio. The V5 does not. The V2 has Two USB Ports, The V5 only has One. Suffice it to say that the Archer C7 V2 and the Archer C7 V5 are completely different routers.
I have a Archer C5400 wont power on, I checked the power chord with a multimeter reads 12V but I believe no power in the router, any suggestions?
