crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Swagwaycrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Swagway Teardown, Swagway Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swagway Teardown, Swagway Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Just how much "swag" does this Swagway pack? The specs are a good place to start looking:
    • Hard ABS outer body casing
    • Aluminum wheels with rubber tires
    • 10 MPH top speed
    • 23" x 7.3" x 7.3"
    • "Top Quality Brand" lithium battery
  2. Swagway Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swagway Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We found some super reassuring warning labels.
    • "Risk of Death or Serious Injury"? Yep, nothing to worry about here.
    • Looks like someone flunked out of a certification. There’s a suspicious hole in that line of approvals…
  3. Swagway Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swagway Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swagway Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Phillips #2 screws secure the two bottom covers, so it's not long before we're well within the belly of the beast.
    • Things look… not bad! Given these boards' reputation, we weren't expecting clean insides.
    • Each foot pad has two infrared sensors. Stepping down on the pad pushes a peg between emitter and receiver; when all four sensors are blocked, you are ready to roll.
    • Those sensor switches live on the backs of the two gyro boards—one for each wheel. Each board is home to:
    • Invensense MPU6050 6-axis gyroscope+accelerometer
    • GigaDevice GD32F130 ARM Cortex-M3 32-bit microcontroller
    • Changjiang Electronics Technology Co., LTD (JCET) CJ78M05 0.5 A / 5 V voltage regulator
  4. Swagway Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swagway Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swagway Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The real star of the show here is the firestarter lithium ion battery pack.
    • Looks like we’ve got a “Shilly-car” lithium battery operating at 36 V with 4.4 Ah (that works out to 158 Wh—just over four times the capacity of an iPad Pro).
    • We’re pretty sure shilly car is a Chinese term for scooter.
    • Inside, we find a tidy block of 20 LG ICR18650B4 batteries with their own protection board. We’re glad to see a reputable brand in here!
    • Their nominal voltage is much higher than the 158 Wh listed on the shrinkwrap. Li-ion batteries shouldn't be fully discharged, so the battery protection board probably limits the pack to the label's specs.
  5. Swagway Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swagway Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Speaking of the protection board: this is a Shenzen Dalishen Technology DDJ10A9.
    • The board in their product photo got a much better soldering job than ours.
    • The four large components are MOSFETs (by GuangDong Mosfet Semiconductor Co., Ltd.) responsible for charging and discharging, and have pretty skimpy solder joints.
    • So far this is the only sketchiness we’ve seen, although it is a bit concerning. These particular solder joints are going to see a lot of power as the battery is charging and discharging.
  6. Swagway Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swagway Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motor power lines have some interesting (read: completely mismatched) color coordination going on—fixers take note.
    • They could also do with some more support and insulation (hot glue) on the solder joints.
    • Here's what we found on a quick tour of the main board:
    • GigaDevice GD32F103 ARM Cortex-M3
    • Six half-H bridge motor drivers, made up of two large MOSFETs each
    • Changjiang Electronics Technology Co., LTD CJ78M05 0.5A/5V voltage regulator
    • Two pairs of 0.007 ohm resistors by the power inlet (R007).
    • Resistors like these, with very low resistance, are used to sense current—helping to shut things down if a motor stalls out.
  7. Swagway Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Swagway Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Saving the best for last(ish), we cracked open one of the mysteriously heavy wheels to get a look at the brushless DC motor.
    • Inside we find oodles of coiled copper wire, three large power leads (one for each of the three phases) and five leads for Hall effect sensors (for position tracking).
    • The motor control board will let the motor know when to switch across those wires, making for a nice smooth ride.
  8. Swagway Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Swagway Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Swagway Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Real quick though, let's take a peek at the UL-certified charger. After all, house fires from charging hoverboards have been reported...
    • To be honest, it looks pretty messy, but we don't like to judge a charger by its... random epoxy? So we consulted charger guru Ken Shiriff of Righto.com, who said:
    • "Looks like a straightforward flyback switching power supply. I don’t see any cause for complaints...The charger looks solid. I don’t see any corners cut. The design is ‘unchallenging’—they didn’t try to make it as small as possible; Apple probably would have made it half the size."
    • So hey, as long as you have a real Swagway, with a real UL-certified charger, you should be fine? Probably.
    • Board-wise, we note:
    • A Leadtrend LD7575 green-mode PWM controller
    • Jaw-like etches that are PCB spark gaps, which protect circuitry from voltage surges
  9. crwdns2935195:0crwdne2935195:0
    • Modular design with good use of connectors means many components can be easily replaced.
    • Only Phillips #2 screws are used—nothing proprietary.
    • The battery is easy to replace.
    • Inconsistent wire colors makes reassembly tricky.
    • We couldn't get the tire off—replacing a worn-out tire will probably mean a new wheel and hub motor.
    crwdns2935097:0crwdne2935097:0
    8
    crwdns2935197:08crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
crwdns2947412:010crwdne2947412:0
These Motors are AC brushless induction motors, not standard DC Motors.
allanxp4 - crwdns2934203:0crwdne2934203:0
I fixed my broken hover board but I'm looking for one of the 4pin hole for the charging cord that goes inside.
Joseph - crwdns2934203:0crwdne2934203:0
Anyone know where the serial number is? Trying to ID the manufacturer of my board--having trouble. Wanna make sure it's not under recall. Thanks! I should add that I'm 99 percent sure it's a SwagWay board.
Lance G. - crwdns2934203:0crwdne2934203:0
Thank you for learn
My problem is I fix my swag way and I changed the sensor then it's start putting own Weel drive forword and ether own drove back side
I hope slovenly this problem with you
Thank you again
Saleh alwaghzah - crwdns2934203:0crwdne2934203:0
Does anyone have a scheme or a photo for the assembly of the whole device? I've got the electronics disassembled and am not sure if the parts are complete.
Sacha Hofer - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 166
crwdns2942667:0crwdne2942667:0 20,115
