The Teardown is pretty much the same as other Samsung Slider phones
Remove the back cover and battery
Remove the 8 screw that hold the back cover down.
Carefully pry back piece off
Start at the bottom and work toward the top.
Use the ipod opening tool to disconnect the Connector
Carefully remove the main board
Make sure to not tear the microphone cable, pry it from the phone carefully
Remove the 6 screws
Pry to ribbon cable assembly loose from the slider
Its glued on the left and right side
Remove the 4 screw the holds the slider to the phone assembly
one of the screws will be behind the hinge
Carefully pry slider assembly loose from display assembly
Remove the tape and pop the connectors and pull all the ribbon cables loose
Carefully pry the speaker loose from the case.
Carefully work the keyboard loose from the display assembly
There are a couple fragile clips that hold it in place
LCD comes out pretty easily
Pry it from the bottom and work up the sides to release it if stuck
The glass can be removed with a little heat from a heat gun or blow dryer
Pry it out from the outside edges working around carefully
This was so helpful! How can I show my gratitude to you for these helpful instructions?
