crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0SONY WH-1000XM3crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. SONY WH-1000XM3 Teardown, Remove ear cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start from the left side. Remove the ear cushion.
    • Personally I start from the up-right side.
  2. SONY WH-1000XM3 Teardown, Remove screws and open up: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SONY WH-1000XM3 Teardown, Remove screws and open up: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SONY WH-1000XM3 Teardown, Remove screws and open up: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all the screws, there are 5 short ones on the upper level and 4 long ones on the bottom.
    • Carefully open the back cover you can see the NFC antenna connects to the mainboard.
    • It seems that the wires tangled under the sticker cause the problem. I tried to sort them a bit and the power button come back alive.
leonw87
crwdns2935283:011/30/19crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Thank you very much leonw87. My headphones are working again thanks to your instructions. I changed the battery first, unfortunately without success.
After I sorted the cables on the board a bit, I stuck a tape over the connection points so that they are better fixed.
Great job from you.
JayJay - crwdns2934203:0crwdne2934203:0
THANK YOU
my headphones fell cause I''m an idiot, used to turn on after many tries so I gave this a shot and worked perfectly
el Foresto - crwdns2934203:0crwdne2934203:0
I dont have enough words to explain how appreciate your help. I have been months with my hearphones left out in a box thinkin they were broken or whatever. You literally saved my life rn bro. Thank you so much <3
zouhair naoumi - crwdns2934203:0crwdne2934203:0
is it possible to replace the Bluetooth module with that of the newer version so I can get multi point connection
Darth Darth - crwdns2934203:0crwdne2934203:0
Had the same issue after mine fell off my head at the gym. Followed your guide and they're working again good as new. Thank you for the guide
Grant Vrban Brown - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 112
crwdns2936753:030crwdne2936753:0 480
crwdns2942667:0crwdne2942667:0 7,056
