crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Rockford Fosagte P300-12crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Rockford Fosgate P300-12 Teardown UPDATE FEB 2025: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Front view
  2. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 8 coarse thread wood screws and gently pry the plate out
  3. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier Face: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier Face: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the 3 knobs and the 1 screw between the 2 10A fuses. then the plastic face should pop off
  4. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier in depth: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier in depth: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Amplifier in depth: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Crossover / Gain
    • Power Supply and output FET's
    • Power Supply Transformer
    • Output Filters
    • The 2 boards are held together by 4 screws on the edges of the PCB, gently pull them apart, they will only be held together by pin headers. Here you can see the 2 output filters and the power supply step up transformer
    • The board with the FEMALE pin headers is the front board with the plugs on it. the crossover network consists of JRC 4850's
  5. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, PSU and Power MOSFETS: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 4 of these "GA7E1S" FET's that i cant find any info on. i would assume by looking at the boards that 2 are the power supply and the other 2 are the outputs
    • There are NO heatsinks anywhere in this unit which i find amazing. but the FETS most likely use the massive copper planes on the board as the heatsink
  6. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Logic: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Logic: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • More jelly bean logic around the board
  7. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Driver: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Driver: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The custom 12" driver. it appears to be a DVC driver, but its just a SVC with 2 pairs of leads going to it
  8. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Removing the Driver: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Removing the Driver: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here's my February 2025 update. i Finally have pulled this P300-12 again to do what i have been requested a few times, and that is to pull the actual driver itself
    • Once you remove the 8 3MM hex head bolts the driver is not glued in but it does fit very snug with the textured vinyl covering making it very difficult to remove from the front. It was MUCH easier to pop out from the back sticking my hand through the amplifier hole.
  9. Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Testing the Driver: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rockford Fosgate P300-12 Teardown UPDATE FEB 2025, Testing the Driver: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here we again see the twin pair of leads going to the SVC driver, they really do NOT want you to remove this thing, each spade terminal is soldered onto the driver!
    • And the answer to the comments, the Rockford Fosgate P300-12's possibly custom spun driver is 2 Ohms
bassblaster505
crwdns2935283:001/25/17crwdne2935283:0
539 crwdns2915208:0crwdne2915208:0
crwdns2947412:023crwdne2947412:0
Nice, if you can do one on pulling the sub out that would be great. I think it might be glued in.
Cometa Soulstar - crwdns2934203:0crwdne2934203:0
I have the 10” version of this sub but believe the amp is identical. I’d like to steal the amp from this to use in a new enclosure. Any idea how many ohms this could drive?
Ian Pitts - crwdns2934203:0crwdne2934203:0
Im not sure, when i did this teardown i never thought about doing an ohms test on the driver. it might be a 2 ohm driver, but if you have the 10”, pop the plate amp out and stick a meter on the driver lol
bassblaster505 -
I have a p300-12 , but the box shape is all wrong for my ‘07 FJ. What obstacles do you see after the teardown for transplanting the amp and sub into a custom fit box? Thanks in advance!
Jason Todd - crwdns2934203:0crwdne2934203:0
i dont see any issues with that idea. just when you get a new box get one thats similar in volume as the original and also sealed as i have no idea how the driver would perform in a vented enclosure. just keep the original rockford box so if you decide to sell it down the line you can reinstall it
bassblaster505 -
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 7,072
