This is just a general teardown guide for the robotic vacuum cleaner Roborock S8 MaxV Ultra.
This only covers the robotic vacuum cleaner, and not the dock as well.
Begin by removing the back and front halves of the top plate.
Start by removing the visible screws.
Now flip the robot over and remove visible screws.
Now simply pull the bottom plate off. If you got all the screws, nothing else should be holding it in place.
Remove the screws on the bumper.
Once you have removed the cover of the bumper, make sure to disconnect the connector that connects the light in the bumper to the motherboard.
Now, flip it over and remove a screw on top.
Flip it over again and remove the rest of the screws.
First, disconnect the connector from the motherboard.
Get the cable out of the housing and through the hole indicated by the arrow.
Flip it over, then get the wire out of the housing. Use your tweezers for this.
Flip it over again, then detach the pipe from the water tank.
