crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Rabbit R1crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Rabbit R1 Teardown, Discharge and power off: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • It is good practice to discharge the battery before operating on a device. The Rabbit r1 is no different.
  2. Rabbit R1 Teardown, Heat up the back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply heat to the back of the unit with a tool of your choice to loosen the adhesive.
  3. Rabbit R1 Teardown, Remove the back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a razor blade or ifixit pick, slowly go around the unit. Be careful not to damage the plastic if you choose to use a razor blade.
    • Be careful when removing the back panel. The battery is attached to the back panel and connected via a ribbon cable.
  4. Rabbit R1 Teardown, A look inside: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • We now have access to the various insides of the Rabbit.
    • Inside, 6 screws attach a motherboard and a bracket. One of the screws is under a tamper resistant sticker.
  5. Rabbit R1 Teardown, Detaching connectors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Marked in blue are the connectors that will need to be removed.
  6. Rabbit R1 Teardown, PTT button.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing all the screws, the PTT button slides out of the chassis.
  7. Rabbit R1 Teardown, Removing the motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you disconnect all the ribbon cables and unscrew all the screws, the motherboard can be removed. Gently pull it out of the body of the Rabbit.
  8. Rabbit R1 Teardown, Removing the speaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rabbit R1 Teardown, Removing the speaker: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker is attached via clips and a screw. After removing the screw, slide the speaker toward the board and pull it up. Make sure to disconnect the speaker before removing it.
  9. Rabbit R1 Teardown, Magic Eye: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the magic eye, carefully take out the two screws and spacers that attach it. Then, gently pull the unit out.
  10. Rabbit R1 Teardown, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the screen is the same process as the back. Use heat and iFixit picks to loosen the adhesive and remove it from the body. Make sure to be careful with the ribbon cable that connects the LCD to the motherboard.
  11. Rabbit R1 Teardown, Teardown Complete: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Rabbit r1 is not designed for repairability, but it has some nice repair-friendly features, like using common screws and not too much glue.
William Urfer
crwdns2935283:009/06/24crwdne2935283:0
408 crwdns2915208:0crwdne2915208:0
Perhaps you could use capitalization and punctuation?
Avni - crwdns2934203:0crwdne2934203:0
Taken care of!
Preston Tech -
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 920
