crwdns2936621:0crwdne2936621:0
- The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
- Many components are modular and can be individually replaced.
- Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
- While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
- The primary access point for all repairs, the rear panel, is firmly glued in place.
crwdns2935195:0crwdne2935195:0
crwdns2935097:0crwdne2935097:0
4
crwdns2935197:04crwdne2935197:0
crwdns2935199:0crwdne2935199:0
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - crwdns2934203:0crwdne2934203:0
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge -
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - crwdns2934203:0crwdne2934203:0
OnePlus 7 pro 8/256
Anita Jajoriya -
do i need to remove the pop up camera if i want to change the screen?
romain.collet - crwdns2934203:0crwdne2934203:0
Where the sensor board is located, my gyro doesn't work, even though I change direction my phone maps doesn't align
Vivekanand P - crwdns2934203:0crwdne2934203:0
