crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nintendo GameCube Controllercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Nintendo GameCube Controller (Official) Teardown, Removing the back: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Removing the back: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Plastic Cards
    $2.99
    • Locate and remove six (6) tri-point screws.
    • If you are unable to get a tri-point screwdriver into the hole (specifically the two in the bottom of the grips), a very small tip flathead may be used. Be very slow and cautious not to strip out the screws.
    • Gently pry the two halves of the controller apart using plastic cards or tools.
  2. Nintendo GameCube Controller (Official) Teardown, Disassembling the triggers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Disassembling the triggers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Disassembling the triggers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four (4) phillips head screws from the interior trigger guards. Pull the trigger guards straight out to access the interior triggers.
    • The screws are interchangeable, but the guards are not.
    • Push up on the trigger base and pull it up and out of the slot it's sitting in. Pull the trigger assembly down and out of the case back. Left side shown, right side similar.
    • The trigger is pushed up by a spring which will send your pieces flying if not restrained.
    • Separate the trigger base from the trigger itself by popping the retention bar out of the bottom of the trigger (purple circle)
    • A flathead screwdriver may be used to gently pry the bar down. Do not bend the bar or break the plastic.
  3. Nintendo GameCube Controller (Official) Teardown, Removing the Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Removing the Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Removing the Circuit Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Buttons and button pads will fall out in the next steps.
    • Gently pull the circuit board up and out of the front case and set aside.
    • There's nothing holding either the pads to your board or the buttons into your front case, so take a moment to make sure you didn't drop any.
    • Remove any buttons you need from the front case. The Z button is the only one of note; there is a metal lever that sits in a groove and a post on the back side of it that sits in a hole to align the trigger.
  4. Nintendo GameCube Controller (Official) Teardown, Circuit Board Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Circuit Board Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Controller (Official) Teardown, Circuit Board Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the analog stick, C-Pad stick, and the pads for the D-Pad and face buttons.
    • Most everything else in here can get a nice soak in mild detergent and water, but the board doesn't want soap or water. A soft toothbrush, Q-tips, and alcohol got her looking much better.
    • Reassemble is opposite of disassembly. Most pieces only fit one way.
  5. Nintendo GameCube Controller (Official) Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Full IC Identification:
    • You may need to enlarge it to view the text.
Skeletwing
crwdns2935283:011/18/18crwdne2935283:0
127 crwdns2915208:0crwdne2915208:0
i cannot find any replacement screws for the controller online. at all. please any equivalent screws if not oem? for the shell not internals.
samm07 - crwdns2934203:0crwdne2934203:0
(6) M2.63 x 8mm pan head self-tapping screws (coarse threads) should do the trick.. if by any chance you're still searching 5 years later. 😅 This kit includes torx replacements for the shell and internals: https://handheldlegend.com/products/torx...
deepfriedfilth -
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 131
crwdns2936753:030crwdne2936753:0 503
crwdns2942667:0crwdne2942667:0 30,665
