Find the tab on the left side of the cartridge.
Use your fingernails to pop open the top from the bottom
BE CAREFUL WHILE DOING THIS. If you aren’t careful, the game case may crack and or not go back together.
Go around all parts of the cartridge and do not crack the plastic.
Remove the top of the Game Card with your fingers.
Show us the other side of the PCB.
You just lift it out of the shell. It is not stuck in there, you can just take it out. You can also find images of 3DS PCB’s online I’m sure.
Where can I find good replacement game card housing?
