crwdns2936621:0crwdne2936621:0
We braved a gnarly midnight line at our local GameStop to bring you this teardown. No expense was spared for your enjoyment.
Hot off the press, the Nintendo 3DS XL 2015 boasts the following tech specs:
"Super-stable, face-tracking 3D"
Addition of the C stick along with new ZL and ZR buttons
Built-in near-field communication (NFC) reader
Improved CPU performance
Upgraded rear-facing cameras and microSDHC support
Making its comeback debut, not seen since the Gamecube era, put your hands together for the C stick. All glory to the C stick.
How do these things work again?
It's time for a face off between the New 3DS XL, and its older brother, the original 3DS XL.
Perhaps the biggest change is the shifting of the cartridge slot to the front of the device, making room for the new ZL and ZR buttons.
It looks like the New 3DS XL has lost some weight too! Weighing in at 329 grams, Nintendo has shaved 7 grams off of the original 336 gram weight.
The New 3DS XL is also slightly larger and thinner, coming in a 160 x 93.5 x 21.5 mm vs the original 156 x 93 x 22 mm.
Also the new one is shiny.
It's a bit hard to see, but there's a very subtle moiré pattern on the New 3DS XL's shiny exterior.
The back cover shows off the usual disclaimer/manufacturer imagery, telling you this is the *New* version and not the old one.
You'll have to remove the stylus before disassembling your New 3DS. After pulling it out, we noticed it to be a bit different than the old one.
It's the same weight as the old one—1.8 grams, according to our
dealerprecision scale. Yet, it's a bit stubbier, and feels a little cheaper.
That's right, you need a frickin' screwdriver to replace the (now micro) SD card. Gone are the days of flappy door access.
And once you're inside, the card and battery are easily accessible.
And very easily removable...
Battery removal and installation in 3 seconds. Hey Apple, take note. This is how it's done.
Two teardowns for the price of one! We never gave you an original 3DS XL teardown (although we have many lovely guides), so here's the skinny on batteries, at least.
On the left is the New 3DS XL battery, with the "old" 3DS XL battery on the right.
It seems Nintendo didn't bother upgrading the battery in the New 3DS XL. Both models feature a 3.7 V, 1750 mAh battery rated at 6.5 Wh.
All it takes is a push from a fingernail to get the micro SD card out of its tiny house. So out it went with little effort on our part.
Speaking of removing the micro SD card, if you're upgrading from a 3DS, 2DS, or 3DS XL, check out our (and Nintendo's) guide on how to transfer your data.
Nintendo hid two screws under a couple of rubber feet; the other six were exposed when we removed the bottom cover. We've been in this game long enough to not fall for that hidden-screw trick.
We push-pinned those little rubbers out of the 3DS, and presto-blamo — cracked it open!
The 8 screws in this step require a smaller screwdriver than a Phillips 00.
i think they are jis #000
I unfortunately have a stripped screw on my refurbished console, and I’ve no idea how I’m going to get it out. Could you please show some steps on solving this issue? Thank you very much if so.
What "new" magic awaits inside the New 3DS XL? Let's find out!
The flappy shoulder bumper buttons stay in the lower case, so we employ a bit of cable-spudgering to separate the pieces.
It looks like Nintendo doesn't care much for internal appearances — they left some uncured powder coat on the interior of the lower case.
My right shoulder button is missing its ribbon mount it was attached directly to the case. Yours is are gray and mine blue. I would like to get the mount but not sure what it is really called[|.]
Okay, what Ouroboros business is going on here?
The circle pad cable is weirdly wrapped over its own ZIF connector, hindering access to...itself.
Our first inclination was to disconnect the ZIF connector and proceed with removing the motherboard. But it's such a tiny, frail connector, and cable, that we decided to remove the assembly first.
Out the circle pad goes! More on that in just a jiffy — first we focus on the motherboard.
Once we got inside, our trusty Phillips drivers started to mysteriously let us down—these screws seemed to be in between two sizes.
Surprise, they're JIS! Now, where do we get ahold of a JIS bit...
With our driver properly equipped, the motherboard comes flying out without delay...
...or not? There's not one, but two cables attached to the rear of the motherboard, just to make things tricky.
Regarding Step 11's attached photo: exactly how ARE those cables supposed to be attached?
Perchance someone could take a photo of their nN3DS XL and show me? 'Cause I was attempting to replace my D-Pad, and now either I hooked something up wrong or (far worse) I broke like ALL of the black ZIF connectors, 'cause my nN3DS XL isn't booting anymore. :(
We do have guides on this device, this is a teardown and not meant to be followed as a disassembly guide. Check out the directional pad guide, it has more in-depth photos for those connectors. If you only broke the locking tabs on the ZIF connector you should be fine, you can use tape to secure the ribbon cables if they slide out. If you broke connectors off the board, you might be out of luck. Hope this helps!
Well, I HAD followed that guide when I disassembled my nN3DS XL. :)
None of the connectors have been physically separated from the board (unless you count the top half of the Circle Pad's connector — the bit that locks down), and as far as I can tell, I've got everything hooked up correctly. :/ But for some reason, it just won't turn on anymore.
I think I'll ask how to get my nN3DS XL working again on that particular guide; it'd probably be more on-topic. :)
Oh good! You can also post in our Answers forum, there's more traffic there, so you may have better luck =)
In the photo attached to “Oh boy reassembly’s gonna be fun”, the ribbon cable that the tweezers are closest to, I have some small dents in the ribbon cable and want to know either if that’s fine or just possibly where to get that ribbon cable from. The reason is because everytime I try to turn it on it has a blue light on and then turns off, nothing, just a black screen.
With the motherboard extracted, we're free to remove the microSDHC reader.
I have added 200gb micro SD card and it is reading/writing it just fine. It shows 999,999 fre blocks.
Any 3ds family system can use up to a 128gb card just fine, as long as it's formatted to FAT32
It's time for some motherboard action!
Nintendo 1446 17 CPU LGR A (custom CPU, likely based on an ARM core)
Atheros AR6014G-AL1C Wi-Fi SoC
Samsung KLM4G1YEMD-B031 4 GB eMMC NAND Flash
Fujitsu 82MK9A9A 7LFCRAM 1445 962 FCRAM (Fast Cycle RAM)
Texas Instruments 93045A4 49AF3NW G2 (Possibly Power Management IC)
Renesas Electronics UC KTR 442KM13 TK14
Any sound chip information?
New 3DS CPU: ARM946 x1 (@134MHz, Frequency down when runs GBA VC) +ARM 11 x4 (@804 MHz on supported title and home menu 268MHz on other)
Anyone know where I can get one of the wifi chips (Atheros AR6014G-AL1C Wi-Fi SoC) for cheap?
the 3ds gpu is dmp pica200
Is there a sound chip information?
The back of the motherboard has a few goodies as well.
Texas Instruments AIC3010D 48C01JW (Possibly Codec IC)
NXP S750 1603 TSD438C Infrared IC
Texas Instruments PH416A I/O Expander
20791, this is the Broadcom NFC chip BCM20791.
Where is it on the board??
The linked webpage about the CPU is for the old one, from 2011. I'd love to see die scans of the new 3DS! Still unsure what the processors in there are.
Break time: We did a quick reassembly, followed by a nostalgia overload.
Now that the tech writers are fed and caffeinated, we'll be moving on...
Hey guys, ever wonder how a circle pad works? Yeah? We did too!
Allow us to present to you Xzibit A: the internals of the circle pad. Here it is in action.
But wait, there's more!
The circle pad consists of a small, donut-ish PCB with traces, a backing plate, and the spring-loaded X-Y sliders.
The X-Y sliders each have two metal contacts that are always touching the PCB.
As you move the sliders up/down and left/right, the metal contacts are adjusting the resistance of the circuit on the PCB.
This, in turn, is registered as movement in whatever game you're playing.
Regarding the spring-loaded sliders: A spring inside the mechanism makes the "stick" always return to center. If you wanted to convert the circle pad to more of a "throttle" type joystick — where it doesn't return to center automatically — all you would have to do is take the circle pad apart and remove the spring found within.
Ah, the game cartridge reader. It sure does bring back memories of the good 'ol days of blowing into the cartridge.
Oh hey, the button board comes out!
The ABXY buttons are right on the board, but the C stick can come and go as it pleases.
Said C stick doesn't actually move or push anything, and therefore seems to be powered by magic.
You nudge it with your finger, and the 3DS just knows. Our best guess is that this actually uses strain gauges to sense how hard you're pushing.
Don't try to dissasemble it! I've tried, then I had to glue it back and it is not functioning now :(
It looks as if the circle pad and c stick use the same connectors would it be possible to replace the c stick with the circle pad and move said circle pad under the buttons?
can you replace the c stick, specifically the rubber part? if so, how? i couldn't seem to find a guide of yours on it.
With the cartridge reader out of the way, we easily remove the D-pad buttons.
(Shake, Shake, Shake) Shake Your Buttons.
The lower screen has a large black frame, perhaps as a defense against over-eager tapping.
This frame also houses what appears to be the NFC antenna for Amiibo figurines.
Always one to stay hip with the kids, Nintendo has expanded beyond AR cards to the collect-to-game cash cow.
Poppin' the lower LCD off some adhesive seems scary, but isn't too bad. No heat required!
The plastic LCD cover is threaded with a very-faintly-visible grid of dots. We didn't notice it at first, and taking a photo of it is near impossible — but it's there! We promise!
Four hidden screws and plastic clips along the perimeter hold the secret to its undoing.
Our opening pick makes the perfect tool for prying apart the two halves of the top case.
Want to see pictures of our cats? Nah, just kidding, that's not a wallet, it's the back of the LCD. These are our cats.
Does anyone know what size screws these are?
You should explain that the cover needs to be pulled down before lifting it. I messed up mine thinking that it needed to be lifted only.
This is a teardown meant for an entertaining look at the interior, not a repair guide. Be sure to check out the step by step guides found on the 3DS XL repair manual for specific details and procedures!
It is here that we realize the 3DS XL is basically built like a giant flip phone.
One side of the hinge is held together with a pin, and the other is hollow to allow the display, audio, and camera, and antenna cables through.
With the hinge pin popped, the lower assembly slides off the hollow pin, and the cables take refuge in a slot, ready for separation.
You need to put an extreme, (did I say extreme?) CAUSE I MEANT EXTREME amount of force, to push the pin out of the hinge assembly.
If anyone is still using this tutorial… I heard that uh it’s “keyed”, just like the original DS and DS Lite I believe. I suppose different revisions of the New 3DS XL may be very slightly different in how they are disassembled, but this is what worked for my two units…
The correct way to do it is to open the console up to the second ‘click’, most of the way open, but not such that the top and bottom half are flat with one another. It’s open at about a 150 degree angle.
From here, you can use your favorite small tool (possibly a small enough screwdriver, tweezers, or even a paperclip can work!) and it should come out without too much hassle.
I was applying all the force I possibly could trying to get out the barrel hinge with the console fully closed, slightly opened, and fully opened, and it didn’t work.
Do note that the top LCD screen will slightly block the barrel hinge from coming out all the way. If it’s still attached, either lift it slightly at that corner or remove it.
Hope this helps!
Thank you dude, this really helped me.
hey man you're a goat for this comment. the video i was watching did NOT do this and i was THIS close to breaking my 3ds. This is by far the MOST PRECARIOUS part of the entire tear down imo and that's entirely preventable if you open the hinge before removing it instead of trying to remove it from a closed position.
i really had to step back and get some perspective while doing this. im an adult and can afford to by another model if i screw mine up but if i was a kid and this was the only 3ds i had there's no way in hell i would recommend anyone do this.
David He -
This step is LACKING OF DETAILS
Let's just remove the camera bar. Oh wait.
There are several cables leading into the side of the display assembly. Our bet is that these control the parallax barrier, used to generate that awesome glasses-less 3D effect.
What's a parallax barrier? Imagine placing a very small picket fence in front of your screen, so that when you look at the display, each eye sees different pixels while they peer around the fence boards.
Then, with a combination of the magic of geometry, and the new face-tracking "super-stable 3D", the 3DS knows which pixels each eye can see, and draws two overlapping versions of the same scene—one for each eye. The combination of these two versions gets slapped together in your thinkpan as a sweet, sweet stereoscopic 3D image.
Good news: The display assembly is only mildly adhered to the frame, meaning we can pop it free with little effort.
Bad news: Its ribbon cable, and two others, are routed through the hinge, and need to be rolled up and pulled through in a horrible, painstaking, risky maneuver.
But then it's free!
Does anyone knows if the upper LCD screen is the same of the 3DS XL? If I substitute a New 3DS XL broken upper LCD for a working LCD from a 3DS XL will it work (plus the eye tracking)?
Front and rear camera(s) bar! Nintendo combined all three cameras into a single bar and cable.
The front camera is watching your every move, in an effort to serve you the best possible 3D with the least possible jitter.
The dual rear-facing cameras track AR cards, and take photos with apparently improved low-light capture.
Sadly, there isn't much component information here. There are no tell-tale inscriptions on either camera board or cables, aside from a vague QR code label that reads "3600 4C11 03YG."
Nintendo 3DS XL 2015 Repairability Score: 5 out of 10 (10 is easiest to repair)
The battery is fairly easily swappable by unscrewing two screws and removing the back cover.
Screws and plastic clips are the primary fasteners, rather than adhesive. Also, no Proprietary screw types are used—only Phillips and JIS.
The top display's cables are routed in such a way that it makes them quite frustrating to remove without ripping them off, and just as difficult to re-seat properly during device reassembly.
There are tons of little components inside the 3DS, which may potentially cause problems if you happen to lose one while performing a repair.
The majority of connectors are ZIF, and it's difficult to ensure each one is connected properly without reassembling the whole thing and starting up the device.
The headphone jack and charging connector are soldered to the motherboard, meaning you need to take out your soldering iron if you accidentally break them.
crwdns2947412:044crwdne2947412:0
The 2 cameras are for 3d photos and the ar cards. The front camera and ir light are for the face tracking 3d
Yea, I noticed she said that backwards
quport99 -
Anyone know if some 3rd party will make case bottoms with a SD card slot on the side via a simple cable?
Not until someone knows how to reverse engineer the motherboard and the MicroSDHC card slot PCB parts. After that, 3rd party components will be available, but it's still risky business/corporate-wise.
Looking at console replacement cases theres not much to do other than match up screw holes and the MICROSD card itself is done via a ribbon/super flat cable connected to A MICRO or normal SD port on the side of the replacement case, no need to rebuild the electronics since its just an extension to the MICROSD port. The replacement case would be a slightly different size but exterior size is not that big of an issue.
********Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015 New3DS XL) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again! :) ********
On step 23: All portable Nintendo's since the original DS have "sliding clips" for the top screen, ie. you have to slide the outer cover slightly up to open it. This way, no efforts or tools are needed (assuming the "hidden" screws are already out). From the pictures, it looks like it's still the same for the new 3DS XL you opened, or am I wrong?
Step 24. HOW THE HECK DO YOU GET THE TOP SCREEN OUT OF THE HINGE!!?? THIS GUIDE DOESN'T EXPLAIN HOW.... I'VE BEEN PUSHING WITH A FLAT HEAD ON THE SMALL WHITE PART BUT NOTHING IS HAPPENING! PLEASE HELP SOMEONE!! PLEASE!!
Nevermind about step 24.... You just need to apply an extreme amount of force on the white hinge to pop it back and take out the screen. They should have mentioned this; it was probably THEE MOST difficult thing to do of all the steps.
Teardowns provide a look inside a device and should not be used as disassembly instructions.
********Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015 New3DS XL) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again! :) *********
You have no idea how much I love you right now. I thought I'd broken a friend's DS after reassembling it, so I swapped out myt motherboard for his only to find neither of them worked anymore after reassembly. What I thought was a $400 mistake was just both top display connectors being upside-down! Someone should really note this in the guide, as it's very easy to do as that's how it sits naturally.
kaise123 -
Broken can anyone guide me the lcd cables I think I messed up cause I hear pop sound and it turns off.
did a LL to XL case swap and I'm having problems with the home button and mic.? Has anyone ran into this? And as for that ZIF connector on them is there a right way and wrong way to connect/disconnect?(specifically talking about mic and the one next to it since this breakdown doesn't label what connector is to what)
I'm also having this problem with my home button and microphone. Very frustrating. If anyone can shed some light on how to properly get this fix, it would be very much appreciated.
Blair -
Its the black ZIF connectors that i'm talking about. they dont lock down all the way.
What are those new ZIF connectors called? Old ZIF had a white tab and locked into place. these new ones are black and doesnt go all the way up or lock back down. What am I doing wrong?
FYI, This *New* 3DS motherboard appears to be a mix of old ZIF and new ZIF connectors. the black ZIF connectors are for the Homebutton and LCD brightness and others.
They should call this the Ibreakit 3ds teardown. Reassembly will never happen because the zifs lifted will result in the home button not working and other problems. Extra care should be taken if you are to remove any of the black zif connectors. I might recommend not lifting them at all.
Hi guys, after I open my New3DSXL the 3D effect slider does´t work anymore. Its like its at 30% or so. When I slide the slider up and down, nothing changes. Any idea what could be wrong?
Sorry for my bad english guys.
I just want that Optimus Prime Transformers coffee mug!!! But anyway I just attempted a repair of the Top LCD screen, did that without many issues, aside from the fact that the area where you have to wrap the display connectors and push them through the hinge. But that all turned out fine. The real problem I ran into was when I got it all back together and was testing the device. The 3D does not work on the top screen, the mic is not picking up any sound, and the home button no longer works. What a mess I've gotten myself into with this one. Any advice? I reconnected everything and double checked everything. And those 3 things are still not working! Ugh!
What is the long red cable with the gold connector that travels between both top and bottom shells?
I think I kinked mine and I really can't tell what it was even supposed to do.
Thanks!
Lol blowing into the game cartridge holder thats what I did with my ds lite
hello..i want know what is the flat related to the 3d slider? cause my 3ds have always that turned on..
No disassembly of the shoulder buttons? They're one of the most common things to break and need replacing
So I am half way through replacing and 3ds xl top screen and have had a piece fall out that I don't know where it came from. Is there a CAD drawing or parts list I can reference? Or at least some company that replaces these things that I can ask a question to?
Hi Landon, you might have better luck posting in our Answers forum, our users are more responsive there. Be sure to post a photo of the part that fell out, to help us identify it!
please do one for the new 3ds regular!
Anyone know if replacing the bottom screen is the same as the older 3ds XL? I was hoping to follow a guide that won't tell me to disassemble things that don't need to be removed, which I thought might be the case if I follow this complete teardown. Thanks!
Hey fellas , I have a major problem with my new Nintendo 3ds XL.When I power on the game,the blue power button stays on about 5second then it turns off with a popping sound.Do anyone have a solution to fix this problem? Please help me.....Thank-you in advance!!!!!
This guide doesn't show how to take the R, L, ZR, and ZL buttons out. It also doesn't show the flex cables for these buttons. I was hoping to see the cables in this guide so I would know for sure that I'm ordering the right replacements without having to take apart my system again.... I just put it back together and realized I forgot to take a pic of the cables :(
someone has the service manual?
Hi there
I have a question here I know this post is old and all but I want to know something about the onboard wifi card I tear mine apart and want to know the pin layout of the wifi card to use on a project any idea’s where to find it
Thanks
Anyone know where I can get a replacement connector for my digitizer? It appears to be the same connector used by the joystick. Even if you don’t know where I can get one, just tell me if you know the connector type/name, and I can try to find it on sale.
Hi there!
I have a question, I changed my new 3ds xl shell and everything works fine, but my hinge doesn’t “click” anymore and the upper screen doesn’t stand still to the middle position. I only can put it on a 45 degrees angle or completely open.
Any suggestions?
Thank you!
Used this guide to disassemble my new 3ds xl, but the smallest cables on the motherboard, the holders don’t seem to close down properly.
how repair the microphone?
Follow the guide for the motherboard replacement until step 8 (included). Then jump to step 13 (only). You need to disconnect one ribbon which is the one marked by a red square on the most lower left part of the picture. Do not lift the flap as it will break if you try to. You only need to pull it gently. You can find replacement on ebay or amazon. Be careful to choose the right model as there are different kind of microphones.
bojano -
I mean hear me out. The dpad, joystick, game card slot, even sd card slot, all are modular and replaceable. also the speakers and cameras etc. I think this is super repairable, like anything can break but the probability of needing to change the whole mainboard is really really low
If anyone is having trouble with the Barrel Hinge, I commented under Step 24.
For fixing the ZIF connector problem (Black ones for Home botton, NFC antenna etc…) disconnect the cable and press softly down the “moveable” part . Then just plug in the cable without any lifting . IMHO this connector hasn't any moveable parts so no lifting at all, just heave the cable a little if you want to disconnecting it.
I just fixed my daughter's 3DS. Thank you guys could not done it without you!
Why does my cpu numbers say 1705 20 its where the 1446 17 is. this is concerning me because I want to replace it with something better but of the same pin layout but I don't know what difference there will be.
My new Nintendo 3ds XL’s thumbstick is sort of torn, and I’m wanting to maybe try to replace it.
I’m aspiring to be able to repair handhelds and such, but I know it’s a long hard process to learn, especially for someone like me who is almost completely new to any kind of tech repair. I’m trying to start small, ie, replacing thumbstick. But I don’t even really know if that is small.
What would all the tools and resources I need, be? To learn to how fix stuff like this. And to fix/replace my thumbstick.
any help is appreciated! Thank you
