crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Mi Band 3crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Mi Band 3 Teardown, Opening the shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Opening the shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Opening the shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Opening the shell is the hardest part here, and it's difficult to separate them.
    • I've used jimmy and hot air gun to soften and slice trought the adhesive.
    • Note the very fragile OLED screen and the ribbon of the touch screen.
  2. Mi Band 3 Teardown, Unclipping the ribbbons: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Unclipping the ribbbons: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Unclipping the ribbbons: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After cracking the shell you have access to the touch screen ribbon and the OLED screen.
    • Use a spudger to unclip the Hearth rate and the touch screen sensor ribbon
  3. Mi Band 3 Teardown, Removing the mainboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Removing the mainboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Removing the mainboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew two Philips PH00 screws at the bottom and use the spudger to lift it up.
    • Next remove the mainboard with the battery. Battery isn't glued to the chassis so it's easy to lift up.
  4. Mi Band 3 Teardown, Removing the OLED screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Removing the OLED screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi Band 3 Teardown, Removing the OLED screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use spudger to lift the orange clip at the bottom and take out the ribbon with tweezers.
    • Next to pty up the screen use the haliberd spudger to cut trough the adhesive under the OLED.
  5. Mi Band 3 Teardown, Removing the hearth rate sensor and vibration motor.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi Band 3 Teardown, Removing the hearth rate sensor and vibration motor.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Jimmy to pry up the hearth rate sensor and gently remove the vibration motor using tweezers.
  6. Mi Band 3 Teardown, Battery removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battey you need soldering iron the - terminal of the battery is marked on the mainboard
  7. Mi Band 3 Teardown, You're done!: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dialog 14683 Main chip
    • 25LQ32 32 Mbit flash
    • Azoteq OLED controller
HAZON THE WOLF
crwdns2935283:003/30/19crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
I need that display for my mi band 3 I am really sad because I broke my display
Mohammad Huzaifa - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 2,776
