crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Mastercraft 17FY2-MC Cordless Drillcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the screws from the casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head screwdriver to remove the 6 screws from the casing
  2. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First remove the two yellow twist-on connectors from the bottom of the handle, then bend the wires away from each other to prevent accidental reconnection
    • This disconnects the negative side of the battery, and removes the danger of touching other parts of the drill while the battery is connected
    • Then remove the two yellow twist-on connectors from the top of the drill, and remove the entire battery pack
  3. Mastercraft 17FY2-MC Cordless Drill Teardown, The battery pack: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The drill uses a battery pack consisting of four NiCd cells each with a nominal voltage of 1.2V. This gives a total pack voltage of 4.8V when all batteries are connected in series.
  4. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove motor assembly from casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Remove motor assembly from casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the charging port, trigger switch, and direction switch out of their slots in the casing. Then remove the entire motor assembly from the casing
  5. Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the drill mechanism from the motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the drill mechanism from the motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Remove the drill mechanism from the motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three screws on the motor with a Phillips head screwdriver to disconnect the drill mechanism from the motor
    • The DC motor (second image) spins a shaft connected to a small gear.
    • The drill mechanism (third image) uses a set of gears to provide more torque to the drill head.
  6. Mastercraft 17FY2-MC Cordless Drill Teardown, Motor control electronics: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Motor control electronics: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mastercraft 17FY2-MC Cordless Drill Teardown, Motor control electronics: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The three parts of the controlling electronics are (from left to right in the first image): the charging port, the trigger mechanism, and the direction switch.
    • The charging port (second image) charges the battery when a DC power supply is inserted into the connector. The port also lights up a red LED while charging.
    • The trigger switch controls the speed of the motor by connecting more of the batteries as the trigger is depressed further.
    • The direction switch controls the polarity of the voltage connected to the motor, which spins the motor either clockwise or counterclockwise.
  7. Mastercraft 17FY2-MC Cordless Drill Teardown, Parts overview: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This concludes the teardown of the Mastercraft 17FY2-MC Cordless Drill
Ian Lang
crwdns2935283:011/15/17crwdne2935283:0
crwdns2942667:0crwdne2942667:0 647
