crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Linksys WRT54Gcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Linksys WRT54G Teardown, Get your Linksys: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WRT54G Teardown, Get your Linksys: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Linksys WRT54G series is a series of Wi-Fi gateways manufactured by Linksys, a subsidiary of Cisco Systems.
  2. Linksys WRT54G Teardown, Antenna Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WRT54G Teardown, Antenna Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let's begin with the teardown! First, unscrew the antennas from the back of the router and set them aside.
  3. Linksys WRT54G Teardown, Front Panel Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys WRT54G Teardown, Front Panel Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys WRT54G Teardown, Front Panel Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lets get into the internals! First, flip the unit over and insert a small flat-head screwdriver in between the warranty sticker and the front panel and gently pry it open.
    • Beware! It may take some effort to pry the panel off. Also, be careful not to damage the motherboard, like I did.
    • This will certainly void your warranty from 2002, in case you wanted to know.
  4. Linksys WRT54G Teardown, Remove Top Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys WRT54G Teardown, Remove Top Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys WRT54G Teardown, Remove Top Panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now, slide the top plastic panel off and put it aside you now have a clear view of the motherboard.
    • Intel TE28F320 Flash Memory
    • Broadcom BCM4712KPB (I think it’s a modem chip)
    • Admtek ADM6996L Ethernet Controller
    • Activity LEDs
    • Issi 42S16400-6T Random Access Memory (unsure how much)
    • An assortment of other chips I couldn't find.
  5. Linksys WRT54G Teardown, Remove Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys WRT54G Teardown, Remove Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys WRT54G Teardown, Remove Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Time to remove the motherboard! Unscrew the single Phillips screw, slide the motherboard and then lift it out.
    • Single Phillips screw
    • Plastic slips holding the motherboard in place.
  6. Linksys WRT54G Teardown, Done!: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're done! Thanks for sticking with me for my first teardown!
    • If you want to reassemble this, just do this guide in reverse order! (assuming you didn't break it like I did)
    OK I followed the disassemble guide as suggested ..... now the bit with
    Step 3 Front Panel Removal I did it exactly and yeah I scratch the motherboard too!!!
    But after more more looking when it was apart I found that there where screws in the front feet that held it on
    Kat - crwdns2934203:0crwdne2934203:0
    Hmm, mine came apart with ease after a bit of prying. About the scratched Motherboard, in hindsight I should have used a plastic spudger. I have another one of these and will look into the thing with the feet and update if needed. Thanks!
    Reed Crosby -
    Under the ruber feet on the blue plastic, there are two screws. You can insert a small screw driver into the hold on the feet, and lift it out. Then unscrew the screws instead of prying it.
    Josh - crwdns2934203:0crwdne2934203:0
    You’re the second person to tell me this. I never saw any sort of screws like that. I have like 2 more of them so I’ll look into adding a step if necessary. Thanks for letting me know.
    Reed Crosby -
Reed Crosby
crwdns2935283:012/07/16crwdne2935283:0
4,389 crwdns2915208:0crwdne2915208:0
Happened to get one of these from goodwill recently and wanted to take it apart to take a look. This was really helpful for doing that, deeply appreciate these teardown posts.
Chris Caldwell - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 8,310
