crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0LG G7 Thin Qcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    crwdns2935195:0crwdne2935195:0
    • Lots of components are modular and can be replaced independently.
    • The battery can be replaced, but adhesive and a glued-on rear panel make it unnecessarily difficult.
    • Front and back glass make for double the crackability, and strong adhesive on both makes it tough to access the internals for any repair.
    • Screen repair, the most common type repair, is not prioritized, requiring an almost complete disassembly while battling tough adhesive.
    crwdns2935097:0crwdne2935097:0
    4
    crwdns2935197:04crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
crwdns2947412:09crwdne2947412:0
哈哈哈哈哈哈哈哈哈哈哈哈
coco - crwdns2934203:0crwdne2934203:0
when the back glass cover is replaced after it is cracked and then pried off, how do you achieve “water proof” again”? Thank you
Richard W - crwdns2934203:0crwdne2934203:0
You have to install new adhesive.
segin2005 -
little gotcha - the replacement kit did NOT come with the side buttons. sadly i moved everything out of the old case into the new case before realizing this, and had to disassemble again. to get your old buttons out, pull up the enclosing black tabs on the sides, pry up the silver stuff with a guitar pick, and push them out from inside (careful or they will go flying). then replace those parts into the new case… working on it right now :D
jinglesboiler - crwdns2934203:0crwdne2934203:0
I change front pannel and now wifi and gsm signals are very weak like i sit besides router signal show 3 bars.. What should i do. And from where i can find a new heat pipe for lg g7
Salma Saad - crwdns2934203:0crwdne2934203:0
what type of adhesive is required to attach the back glass and reseal for IP rating?
Fritz - crwdns2934203:0crwdne2934203:0
I have signal issue with my lg 7 some time comes some time it's very hard no service issue mostly when I am traveling
sardar toqeer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 44,967
