crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Krups ESSENZA Nespresso XN 2140crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Preparations: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Preparations: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the device from the mains to begin.
    • Remove the water container and tray.
  2. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove 4 bottom screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove 4 bottom screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 bottom screws that hold the side panels. You need the oval drive bit for this.
    • Leave the other 2 bottom screws in place, these hold the bottom plate in place.
    • When reassembling, take care not to over tighten these screws. When in doubt, take 1/4 turn back.
    • Improvement: As these oval head screws are (intended to be) a nuisance, you may want to replace them with similar screws with a more common head.
  3. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the machine on one side, gently push the bottom edge of the side panel towards the top and lift it out.
    • Unhook the panel from the top.
    • Repeat with the other side panel.
    • The panels are identical, so there's no need to remember which was left or right.
    • When reassembling, make sure the bottom of the panel clicks fully closed before inserting the screws.
  4. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx T120 to remove the two black screws that hold the lever, one on each side.
    • Open the lever and slide it upwards from its axle.
    • When reassembling, the axle needs to be turned vertical before you can slide the lever back into place.
  5. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx T10 to remove the 2 screws that hold the cover of the brew unit at the front
    • Remove the last screw (T10) of the cover, located at the back and underside.
  6. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the brew unit cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the brew unit cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the brew unit cover back so that it comes free.
    • No force needed, some manipulation will do the trick.
  7. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the clips that hold the brew unit, one on each side.
    • With your thumb(nail), push one sideways and and forward so that it frees the clip.
    • This takes a bit of force, but does not need to move the clip far.
    • Repeat on the other side.
  8. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the spout: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With both clips unlocked, remove the spout with a tilting downward motion.
    • When reassembling, you might want to temporarily loosen the front screws from the next step (9) to give the spout more room.
  9. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T10 ro remove the 4 screws that hold the the brew unit, 2 on each side.
  10. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Lift the brew unit off: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Lift the brew unit off: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do NOT remove the hose
    • Lift the back of the brew unit.
    • Pull it backward until free.
    • Put it next to the machine, but do not put much strain on the hose.
    • Clean the spout, the front of the brew unit and anything that needs cleaning.
    • Once dry, it is ready to reassemble.
Altijd Ellende
crwdns2935283:003/29/21crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Anytime, I'm glad I could help!
FarmYard Gaming -
Is it possible to change the o rings of the brew units?
Martin Müller - crwdns2934203:0crwdne2934203:0
Hi Martin, I am not sure which o rings you refer to. Can you be more specific (photo perhaps)?
Altijd Ellende - crwdns2934203:0crwdne2934203:0
Zeer fijn van deze info al gedaan en is terug in orde ok dank u.Marcel
Marcel - crwdns2934203:0crwdne2934203:0
This worked for me. The spout was clogged up with dried coffee and metal residue from the pods… Thank you for the guide @altijdell
honakrisi - crwdns2934203:0crwdne2934203:0
Glad it helped!
In my experience, 9 out of 10 times cleaning solves the leakage, but the design does not allow you to clean the spout without taking the Nespresso apart :-(
Altijd Ellende -
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 102
crwdns2936753:030crwdne2936753:0 420
crwdns2942667:0crwdne2942667:0 10,425
