Amazon proposes to offer users a full media experience with their $199 tablet. It didn't take long until we decided to see what they crammed inside this value package.
Did this teardown kindle a fiery passion for gadget disassembly in you? Follow @ifixit on Twitter to stay up to date with the latest teardown antics.
We have only one burning desire; let us tear into this Fire.
7" Multi-Touch Display with IPS Technology
Dual-Core Processor
512 MB RAM
8 GB Internal Storage
802.11b/g/n Wi-Fi Connectivity
Custom Operating System (Based on Android 2.3 Gingerbread)
In case you couldn't identify the Kindle Fire by its sleek looks, the back panel has been stylishly embossed with "kindle." The smooth, rubberized texture of the panel complements the small size quite well to provide a nice feel when holding the Fire in one hand.
The Kindle Fire is officially identified as model number D01400.
According to the power specifications listed on the back side of the Kindle Fire, an input power of 5 V DC at 1.8 Amps is suggested. Why is this important? A computer USB port typically puts out no more than .9 Amps (USB 3.0), which means it'll take a looong time to fully charge the tablet through USB.
The Fire has a very simplified design that includes a mere two ports and one button—all found on the bottom of the device.
The first port is a standard 3.5mm headphone jack, but the volume must be controlled from inside each app, as there are no external volume buttons.
The port in the middle is a Micro-USB port for connecting the Fire to your computer. The Fire can also charge its battery when plugged into a computer, though it will take longer than charging directly from the AC outlet.
The only button on this tablet is a power button, located on the bottom of the Fire right next to the ports.
The Kindle Fire has a similar port configuration as the iPad 2, utilizing only a single port for data transfer and charging.
The Fire's dimensions are 7.5" x 4.7" x 0.45". Compared to the iPad 2 whose dimensions are 9.5" x 7.3" x 0.34", the Fire looks a little like a chew-toy for the much larger iPad 2.
crwdns2935267:0crwdne2935267:0iFixit Opening Picks (Set of 6)$4.99
Our old friend, plastic opening tool, comes to our aid as well as our musical friend, the guitar pick.
A little prying and plucking and the case's halves yield to our efforts.
Thankfully the Kindle's case separates with a lot less effort than a certain product line we know.
Removing the back case reveals the motherboard and a behemoth of a battery. Note the shiny metal plates on the back case that help provide protection for the internal components, as well as heat sinking and EMI shielding. Unfortunately, this mirror-like shielding inevitably results in a narcissistic battery.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Only one connector and some glue keep this monstrous battery in its place—no match for our trusty spudger and plastic opening tool.
With the battery freed, we take a closer look at the Fire's 4.6" tall x 4.3" wide Li-Ion battery.
This battery sure puts out... 16.28 Watt-hours, to be exact. However, due to the size of the Fire, its battery's 3.7 V potential and 4400 mAh capacity don't quite stack up to the specs of the iPad 2 Wi-Fi's battery.
The touchscreen controller is easily detached from the motherboard after removing a few screws.
To gain access to the motherboard, we must first disconnect a couple of connectors from their respective sockets.
My Kindle Fire took a joy ride on the front of my fiance's car. It slid off during a stop and was later picked up, which appeared to be unharmed, since it was in a case. Well, it just sits at the load screen and never loads. What component should I look at in detail. I has a small scratch at the speaker end. I took off the cover and I don't see anything obvious.
A few more twists with the Phillips #0 from our 64 Bit Driver Kit releases the motherboard from the Kindle's grasp.
We put on our classy monocle magnifying glass to help us identify the ICs:
Samsung KLM8G2FEJA 8 GB Flash Memory
Hynix H9TKNNN4K 512 MB of Mobile DDR2 RAM
Texas Instruments 603B107 Fully Integrated Power Management IC with Switch Mode Charger
Texas Instruments LVDS83B FlatLink 10-135 MHz Transmitter
Jorjin WG7310 WLAN/BT/FM Combo Module
Texas Instruments AIC3110 Low-Power Audio Codec With 1.3W Stereo Class-D Speaker Amplifier
Texas Instruments WS245 4-Bit Dual-Supply Bus Transceiver
Does the presence of the Jorjin WG7310 WLAN/BT/FM Combo Module indicate that the Fire is capable of Bluetooth in its hardware? If so, it'll be exciting to see if CyanogenMod can enable it -- as it did with the Nook Color.
Yes, it does - and there's been a lot of folks seeking this Holy Grail. No joy yet, though.
I hear that there is an internal micro SD card slot on the motherboard.
Can you please outline which connector that it is?
Mine is open - and I do not see any such thing.
Can the 8GB Samsung Flash Memory be swapped to retain previous data? Thanks! Jason
Can't charge mine anymore anyone know where to get a new charging port from?
I meant my Kindle fire HD BTW ;-)
crwdns2935267:0crwdne2935267:0Heat Gun$24.99
I would like sysboot mappings. Can you remove the processor and map to the resistors on the top right? This would allow UnBrickable mod on this device a lot easier. I would like to get one for teardown. It would make developing on this device easier. But please, map out this resistors to their pads.
Continuing our IC exploration, we decided to sneak a peak under the Jorjin cover. We uncovered a Texas Instruments WL1270B 802.11 b/g/n Wi-Fi solution.
According to Chipworks, the WL1270 is an older chip that was designed to work with the TI OMAP 3530. It's interesting that the Fire has it, given that it's coupled with the newer OMAP 4430.
Do any of you know if removing the whole Jorjin WG7310 WLAN/BT/FM Combo Module from the circuit board would cause any problems for the rest of the device?
The reason I ask is I heat gunned it off but I may have taken something extra off.
The Fire still "works" as in it turns on and I can run apps. What doesn't work is the Setting>Device menu. When I try to access it, the Fire locks up and I have hard reset it. I also can't get it to mount as a removable drive to my laptop. When I connect the USB cable the Fire looks like it mounts and the "eject hardware" shows a drive letter but under explorer there is no drive letter. When connected via USB the Fire has an orange spinning circle where the disconnect button use to be.
So do you think removing the Jorjin Module did all this or do you think I might have removed something extra in the process?
PS. I have my reasons for wanting to remove the wireless feature..
One more screw holds the power status LED board in place.
The Kindle Fire's sole button (located on the motherboard) is used to turn the device on/off or tell it to sleep/wake.
A couple more Phillips #0 screws are removed from the Fire and off comes the speaker assembly.
The speaker assembly seems about on par with the speaker assemblies of some other tablets.
How many watts in speakers .
What is blue Ribbon cable? Is that a Flaxible Flat Cable?
What type of that cable?
What do the Kindle Fire and a fruit fly have in common?
Thanks to the help of our Phillips #0 screwdriver, now neither have a backbone.
The long L-folded flat cable connects to a small PCB in the lower right of the first photo of step 13. What is this small PCB used for?
Looks to me like its an ambient light sensor. You can see an opaque dot in the top left corner of front view photos.
Cas -
That small PCB pokes through a hole at the top of the display bezel, which tells us that it is likely the ambient light sensor.
Would be nice to know what it is in the upper left corner. Even the guys at Amazon are clueless. Responses are "It is PROBABLY a light sensor". Could someone find out for sure? I am surprised there was no mention of it in the teardown at all.
Separating the display from the glass was a breeze, which was a nice departure from the usual fused glass ordeals.
Don't be fooled by the display's current state of black lifelessness. When powered on, the LG-manufactured 7" (diagonal) display gives users an eye-pleasing array of 16 million colors at a resolution of 1024 x 600 pixels.
Sharing the screen with friends and family is made easy thanks to the application of In-Plane Switching (IPS) which allows for a wider viewing angle.
Here we have the front panel assembly in all its glory.
The touchscreen controller is designed by ILITEK and is marked as 2107QS001K A95B8F416 A2130B002
The audio plug evidently includes audio in. Standard 4 conductor (2 ch stereo out, 1 in like iPhone headset plug). Some audio apps apparently work okay with this.
The last two strings of the touchscreen controller identification seem to be batch-specific. Over at the TechRepublic is a nice picture of this piece as well and the last two strings are A95B9F695 A2135B010-20
Kindle Fire Repairability Score: 8 out of 10 (10 is easiest to repair).
The rear case is very easy to open, granting trouble-free access to the internals.
All the fasteners found inside are Phillips #0 screws—one non-proprietary screwdriver is all you need.
The LCD is not fused to the display, making replacement an easy task, if necessary.
Simplistic design and limited functionality means fewer components and less headache for disassembly.
A decent amount of adhesive is used on the battery and motherboard, meaning some prying and gentle working is required for disassembly.
The glass panel is fused to the front plastic frame, meaning a heat gun is required for replacing cracked glass (or you have to replace both components together).
crwdns2947412:035crwdne2947412:0
Just stumbled on this from the front page of google news, nice work guys!
You know how we do it brah lol =)
Is the power button a solid cylinder, or is it a capped tube? I ask because I'd like to file down the protruding portion of the button. (I keep hitting it inadvertently, and shutting the KF down.) Is it possible to grind away a fraction of the protrusion without wrecking it? Thanks!
You'd be safe - it is just a sprung plastic pusher that contacts a micro switch located 0.7 cm further inside (on the 'mother board').
Dear iFixit,
What is in the upper left hand corner under the bezel. Is it a sensor of some sort ? I tried putting my finger on it, but the display brightness did not change. (the object in question is nearly invisible, but can be seen if you shine a light on it.) Could this even be a camera lens ?
Just learned that it is indeed an ambient light sensor. The reason the display brightness didn’t change when you blocked the light to it is because Amazon didn’t keep the sensor functional for long. One website I visited claims that Amazon disabled the sensor in the first software update because some users reported that it was acting erratically (Source: http://hack-a-fire.blogspot.de/2013/01/t...).
summary review Kindle fire vs ipad2@http://www.kd-ebook.info/2011/12/review-...
and Pls visit KindleStore by amazon.com @ http://astore.amazon.com/whatkindle-20
thank you for visit :)
It's 8GB on paper, but when you hook it up to your PC via USB it only lets you load 5GB of content. I think this is a hard partition to protect the OS and perhaps other loaded content. Whatever it is, it's a little tight for me.
My micro USB connector got yanked sideways - resulting in needing perfect positioning to get it charged and connected to a PC via USB. I followed the procedure here, and found solder joints broken - a bit of really fine scale re-soldering, and good as new. Here's some additional info: 1) Pry the bottom OUTWARDS away from the body to disengage the plastic snap-in joints. 2) There are THREE ribbon cable connectors that have a latch that flips up to disengage. 3) Lift the edge of the "mother board" that is closest to the battery (after screw removal) to disengage 'mother board'
Step 4,5,6:
Be careful of the wi-fi antenna connector and the routing of the cable. Carefully remove the cable from its socket, and remember how it went in when it comes time to replace it. I had a heckuva time getting that tiny connector back into its port. Without it, your wi-fi signal strength will not be sufficient to make a constant connectioin into your network
ifixit staff: If possible, show a photo of the connector and the cable in its proper position and when it has been removed. Perhaps a close up photo of the cable connector and the port.
Thanks for a GREAT resource, I used the ifixit tear down guide to replace the battery on my wife's Kindle Fire, then discovered a better helpful photo and comment in the Kindle Fire Power Button ifixit guide.
Yes, I was reading under a bright sunny sky the very next morning I received it. It's not as "eye friendly" as a black/white Kindle but tolerable. Ironically, bright colors such as magazines are a bit washed but that's to be expected. Just like a real magazine gets a sun glare the same thing happens with the Fire. Again, it's still readable. Just saw this on:http://amzn.to/13vsfdo
Hello,
I am writing a dissertation on the carbon footprint of a kindle fire, the only problem is I cannot find out the weight of some of its components! I know this is a long shot but would you know how much the screen, motherboard and plastic back weigh?
Would so appreciate any info you could give me!
Thanks so much,
Christina
Hi Christina. I too am doing a project (LCA) on the kindle and would love to learn more about the weights and impacts that you have found. How does someone best get in touch with another this through this type of forum? I would appreciate it if you could share your findings through a dropbox link or the like and post it here as a reply to this message. Kind Regards - Nicc
Nicc -
Hello my headphone port on my kindle fire hasn't been working.... am I able to fix it by tAking the kindle apart
So what if it is really messed up like cracked screen red green & yellow lines running through it. Is it worth fixing? I myself wouldn't do try to fix it. So is there a place that might repair it and not charge half my body?
Anyone know the value of this resistor?
the place where i plug in my usb cable to charge the battery seems to have a missing piece of the terminal that it connects to.how would i get it to work so i can charge it again?
I cracked open my Kindle Fire 1st gen to replace the speakers, and found that the parts don't match! The WLAN cover is COMPLETELY different from the images above, and the RAM module isn't of the same manufacturer. Their RAM module is from Hynix and my RAM module is from Elpida! Unnoticed hardware changes between batches of Kindle Fires!
I'm replacing the screen on my wifes kindle fire and there is a black film that is stuck to the busted screen and it don't want to come off of the old screen. The new screen I have don't have this. What is it and do I need to buy one and where can I find it?
looking for the replacement usb port. any reccomendations on where to acquire this item?
Hi Joe, find the piece you mention ?, I'm looking for it
Eva -
I looove my kindle and it recently stopped charging.I was going to lay it to rest but thanks to this post I'm going to try a repair by battery rep. Thank you for giving some gut!!
Hi Missy shelli,
This is a teardown, and not a great repair guide, check out our battery replacement guide for step-by-step instructions!
This is great instruction. I appreciate the work involved in repairing a device like a tablet. I was able to follow the directions with ease and understood them, and now I have two questions; first, my charging port is supposed to have five connectors, I can only see three. It looks like the others were ripped away, and I actually found one piece floating around after opening the case, wasn't sure what it was until I got to the port, the question is where in the !&&* do find another port to replace.
Second question is I know the wires used to charge the battery are red and black, would anybody happen to which two they are? the connector has several colors, I only need to get power to the battery, so that i can charge it.
All of the black wires on the battery are connected together, and all of the red wires are connected together. However, charging a lithium battery is not so simple as connecting a power source and waiting a while. Excessive charging current or voltage can cause a nasty fire or explosion. The white, yellow and blue wires to the battery are for temperature sensor and possibly other monitoring circuitry. or sensors. It is not a good idea to bypass these.
If you are intent on manually charging the battery (for example, if it is discharged below the safety cutoff threshold and you want to try to salvage it, limit charge current to 0.08 Amps (80 mA), and absolutely do not let the voltage applied to the battery exceed 4.20 Volts. Watch the battery to make sure it does not overheat or swell; if it does, disconnect power immediately.
It’s much safer and easier to replace the broken USB jack and let the on-board power management chip take care of charge control.
Wow, really really well articulated tutorial. I never found such an easy tutorial about anything. Bravo David Hodson.
how nust cost to repair kindle lg
how must does it cost to repair LG kindle
What is the output of the 1st gen screen. Also, does anyone know if it would be possible to wire the screen up to a raspberry pi?
My arrow on the bottom of the tablet keeps turning off.i can't play games or check my email. It shuts off as soon as I turn on one of the apps.
My Amazon Kindle fire will not charge and the connection prongs in the kindle broke and it has not way to make a connection. Is there people that can fix it or is it no good anymore?
hello do you know if this tablette can work only with usb plug by removing the battery before ( without battery at all)
