JBL Boombox Teardown
  1. JBL Boombox Teardown, Sacar embellecedores: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Boombox Teardown, Sacar embellecedores: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Boombox Teardown, Sacar embellecedores: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Consejo: Para que sea mas facil, yo apoyaba el altavoz contra el suelo y lo hacia girar.
    • Girar los anillos ondulados laterales en sentido contrario a las agujas del reloj.
    the ring needed to be twisted has a ~ shape. this shape make the twisting tighter. you to turn them CCW
    Miguel Cretu -
    Miguel is correct, it definitely does work. If you have the correct kind of speaker, it comes off with a twist, but you have to push really hard. To quote from my guide I made on the subject, "Stand the speaker up and push down hard, and you can use a counter-clockwise motion to remove the ring.
    Please note that you have to push down HARD to get the amount of torque needed. Probably harder than you think at first."
    JBL Boombox Tweeter Speaker Replacement
    Justin Castle -
    Do what @erelectronics recommends. As I mentioned in the step: I was pushing the the speaker agains the floor and then it's a little easier. Take in mind I didn't found any guide online so for me it was even more difficult as I had to find the correct way to remove those rings.
    Miguel Cretu -
  2. JBL Boombox Teardown, Desatornillar asa: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Boombox Teardown, Desatornillar asa: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Boombox Teardown, Desatornillar asa: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Una vez sacado el anillo, podemos acceder a los tornillos que hay debajo, que fijan el asa al cuerpo principal.
  3. JBL Boombox Teardown, Sacar asa: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Boombox Teardown, Sacar asa: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sin miedo pero con cuidado, tiramos de los aros de plastico hacia los lados del altavoz hasta que vayan saliendo.
    • Cuando han salido de su posicion, podemo tirar del asa hacia arriba y un lateral para sacar el lado contrario.
    You will need to bend the handle/plastic slightly to get it to come loose. mild force is needed until one of the sides is clear enough that you can lift the handle up over the speaker.
    Victor Koch - crwdns2934203:0crwdne2934203:0
  4. JBL Boombox Teardown, Sacar emboltorio de tela: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Boombox Teardown, Sacar emboltorio de tela: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Boombox Teardown, Sacar emboltorio de tela: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Por la parte de abajo, introducimos una herramienta fina (destornillador, cuchillo,...) en la raya de union que hay entre las dos mitades del embellecedor de tela
    • Levantamos/apartamos la mitad que queda en la parte trasera del altavoz para accder a los tornillos (2 en cada lado)
    • Sacamos esos tornillos
  5. JBL Boombox Teardown, Sacar emboltorio de tela: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Boombox Teardown, Sacar emboltorio de tela: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Una vez sacados los tornillos que sujetan la tela, la abrimos como si fuera un libro.
    • Nota: Parece que se vaya a romper pero no es asi, hace de muelle y se puede abrir sin problema
  6. JBL Boombox Teardown, Extraer tweets: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Boombox Teardown, Extraer tweets: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Aflojamos los tornillos que sujetan las gomas con los tweets
  7. JBL Boombox Teardown, Extraer tweets: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Boombox Teardown, Extraer tweets: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Levantamos las tapas con los tweets con cuidado
    • Desconectamos los los cables de sde la placa.
    • Nota: Los conectores van sellados con cola. Tirad con cuidado. Sugiero primero romper de alguna forma esa cola antes de sacar el conector
    • Nota: Sujiero separar los tweets al sacarlos ya que tienen cables de longitud distinta
  8. JBL Boombox Teardown, Extraer altavoces-subwoofer: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Una vez sacados los tweets, podemos proceder a sacar los sub-woofers. Para eso se aflojan los 8 tornillos que sujeta cada uno del sub-woofer.
    • Nota: Sugiero separarlos ya que tienes cables de diferentes longitudes
    • Despues de los pasos anteriores, tendremos acceso a la placa principal.
    • No tengo muchas mas fotos pero una vez sacada la placa, tambien se puede acceder a los tornillos de la bateria y tambien a la placa de la botonera de arriba y los contactos de atras
    • NOTA: La antena BLUETOOTH esta sujeta a la carcasa con cinta doble cara. Se recomienda primero despegarla antes de extraer la placa
    • PD: Siento no tener mas fotos del proceso
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
Miguel Cretu
crwdns2935283:010/05/17crwdne2935283:0
373 crwdns2915208:0crwdne2915208:0
I'd like to repair the volume knob on a Xiron boombox. Seems to be a loose contact of sorts. Any help available?
rayjay - crwdns2934203:0crwdne2934203:0
you need to open the device and use a tester for check the button works well.
you would need an isolated wire in order to simulate the volume button to see wheter the problem is button fisically or maybe something deeper
Miguel Cretu -
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 268
crwdns2942667:0crwdne2942667:0 6,619
