How to disassemble Geek Bar disposable vaping unit.
Use a wood chisel (~1 inch) along the seam to break loose the clear cover. The cover snaps into place but may be lightly glued.
Pull out the internals. You will need to push in the on/off switch at bottom of unit to get the insides to slide out.
Detach tank. Note location of wiring if you are going to reassemble unit.
Pull off top of tank.
Pull heater unit out of steel sleeve.
Remove flat wick from heater
Observe basket style heater unit. Resistance readings: blk-grn: 1.1 ohms; blk-red: 1.1 ohms; red-grn: 2.2 ohms
Unsnap the circuit board from the L-shaped plastic holder.
View board.
The lip piece can be unsnapped from the inside, pulled out from the top and disassembled as shown.
I was looking for exact directions on the lip piece filter and rubber because the filter in mine has a film over one side and it’s just like cotton on the other. Does that go up or down inside the gasket or just on top of it when I took it apart mine hit the floor, so I have no idea. Thank you.
Sorry, I don't recall how that little oval shaped piece was oriented. It doesn't appear to filter anything & maybe its used to seal the air passage going to the mouthpiece. That film may have been a piece of double sided tape used to hold it in place during assembly ... That is a guess.
Greg -
crwdns2947412:08crwdne2947412:0
Perfect illustration and pics.
Hell yeah thank you
love u man, sooo much
So satisfying. Now it's a perfect secret-stash container too!
I used this to open it and fix an auto-fire/over-fire I was experiencing. I've had it happen before but simply cannot afford to buy another. After opening, I powered it on, hit it & it hit fine. I then switched it off, put the switch cover back on, hit it and back to auto/over-firing again. I removed the switch cover and it was fine, closed it back up without the switch cover and it hits fine, pulls more air in, but I am thinking based off my understanding of vaping herbs that a faster, higher airflow willl create a lower temp & therefore, it shouldn't use up as much fluid per use even tho I have it set to pulse mode. This won't effect the fluid guage as it's predetermined and even if you add fluid while at say 60%, it will not change the level shown or the amount it displays. I'm used to having them display 0% and having several days of full flavor/hits even after this. Thanks for the breakdown, clean, simple, easy to understand. I've opened the Pulse X but never one like this, so thanks.
Thank you so much this is going to help me with one of my projects.
541125040653
Alee Sg -
I dropped mine the water and now it’s not working so I’m putting the juice part in my other one that’s just hit 0
