crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Franklin MWD-460Acrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Franklin MWD-460A Teardown, Fully Assembled: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Franklin MWD-460A Teardown, Fully Assembled: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is the fully assembled Franklin MWD-460A Electronic Dictionary.
  2. Franklin MWD-460A Teardown, Battery Compartment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Battery Compartment: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Battery Compartment: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the back of the case, locate the battery compartment, its cover, two grooves, and the tab (which locks the cover in place).
    • Release the cover by pulling down on the tab with a fingernail.
    • While holding the tab down, insert the opening tool into one of the grooves and gently pry the cover off.
  3. Franklin MWD-460A Teardown, Separating the Panels Part 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Separating the Panels Part 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Separating the Panels Part 1: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery grooves.
    • Remove the batteries by inserting the prying tool into the grooves (sliding it underneath the batteries).
    • Locate the one screw inside the battery compartment, loosen it, and remove it.
  4. Franklin MWD-460A Teardown, Separating the Panels Part 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Separating the Panels Part 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Separating the Panels Part 2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the six tabs holding the two panels together along the sides.
    • Insert the prying tool into each of the six grooves and gently separate each tab from its insert on the other panel.
    • Finally, separate the panels from one another.
  5. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the three screws holding the upper circuit board in place.
    • Loosen and remove the three screws.
    • The screw in the top right corner is also holding a tab in place so remember where it goes.
  6. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1 Continued: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the upper circuit board to locate the up/down keypad and remove it.
    • Be careful when moving the upper circuit board as it's attached to the LCD screen and the lower circuit board.
  7. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 2: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the eight screws holding the lower circuit board in place.
    • Gently pull up on the tape to expose the eighth screw.
    • Loosen and remove the eight screws along with their washers.
  8. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the two circuit boards (along with the attached LCD screen) away from their case.
    • Now peel the lower keypad from its case.
  9. Franklin MWD-460A Teardown, Full View of Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is a full view of the disassembled Franklin MWD-460A Electronic Dictionary.
Chris L
crwdns2935283:012/17/14crwdne2935283:0
1 546 crwdns2915208:0crwdne2915208:0
How can I fix the screen? The letters are so faded. :(
Paola Paniagua - crwdns2934203:0crwdne2934203:0
MWD-460A
Not used for last about 7-8 years. Now I replaced the batteries but Lcd display is blank or not switched on. Please help.
Kaleem Baig - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,250
