crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Fnirsi FNB58crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Fnirsi FNB58 USB tester Teardown, Remove screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Remove screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start with the back side and use a TR6 bit to remove the four screws (circled in red).
  2. Fnirsi FNB58 USB tester Teardown, Remove covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Remove covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Remove covers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove first cover by carefully prying (e.g. with an old (credit) card)
    • It should not take much force
    • In the created opening, roughly where the red square marking is, there is a small plastic latch/hook.
    • Lightly press it down and pry on the back cover with the bluetooth logo.
    • This is the hardest step. Be patient and careful.
    • There is two more latches/hooks, these should not pose a big problem once the first one came lose.
  3. Fnirsi FNB58 USB tester Teardown, Remove electronics: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Remove electronics: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Remove electronics: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide out the electronics.
    • You can see a screen on a PCB in a black plastic frame.
    • Remove the PCB from the frame
    • Remove the black foam tape
    • Remove the two screws (redcircles) next to the USB-A connectors.
    • Carefully bend the plastic (pink rectangle) on the menu select button to remove the PCB.
    • If you have the FNB58B variant you should see the bluetooth module remain in the frame (green square).
  4. Fnirsi FNB58 USB tester Teardown, Reverse engineering: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Reverse engineering: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fnirsi FNB58 USB tester Teardown, Reverse engineering: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screen labelled "NFP200H-20A", could not identify further. Probably some standard TFT display with SPI/I2C.
    • Backside main PCB:
    • Red square: Artery AT32F403A CGT7 (Main microcontroller) with orange square: W25Q128JV (128M-bit Serial Flash Memory with uniform 4KB sectors and Dual/Quad SPI)
    • Blue square: 3PEAK TPA626 TPA626 (Bi-Directional Current and Power Monitor)
    • Green square: RS2228 MCO7117 (High-Speed USB 2.0 (480-Mbps) 1:2 Multiplexer/Demultiplexer Switch). Probably to switch between the USB micro and -C inputs.
    • Pink square: IC labelled IV7NS. I think it might be a MPS MP2451DT step-down converter. Probably to always provide the 3.3V logic-level voltage for the ICs.
    • Yellow squares: could not identify. One (presumably) QFN14 labelled "UAAC CEH" and one with unknown form factor "WL5 J3".
    • Bluetooth board: pogo-pins to make contact to main board and Tuya BEKEN BK3432
Rene
crwdns2935283:012/12/16crwdne2935283:0
492 crwdns2915208:0crwdne2915208:0
What is the marking on the resistor? to the middle right of the yellow square connected to pin 7, mine shorted out and is illegible.
Jeff Jordan - crwdns2934203:0crwdne2934203:0
I figured out the Bluetooth protocol for this if anyone wants a good way to log this without their crappy software. https://gist.github.com/parkerlreed/0ce4...
Parker Reed - crwdns2934203:0crwdne2934203:0
UAAC CEH скорее всего FUSB302BMPX. wl5 j3 это точно kxtj-1057 акселерометр, проверено заменой.
Сергей Корнеев - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 1,981
