crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Flipper Zerocrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Flipper Zero Teardown, Caution: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not use alcohol or alcohol containing cleaners, tissues, wipes, or sanitizers on the acrylic window! It can permanently damage it.
    • The top shell, the IR cover and the acrylic window are one solid part and can't be disassembled. (They pop out with a bit of force but wont go back in as well without some sort of glue)
    • The Flipper Zero only uses two types of screws:
    • Long screw size is M1.7x8
    • Short screw size is M1.7x4
  2. Flipper Zero Teardown, Remove the microSD card: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Eject the microSD card (if present) by pressing it with your fingernail.
  3. Flipper Zero Teardown, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
  4. Flipper Zero Teardown, Open the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flipper Zero Teardown, Open the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flipper Zero Teardown, Open the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
    You need to press a little stronger between the GPIO ports than next to the SD-card slot.
    EpicErik HD - crwdns2934203:0crwdne2934203:0
  5. Flipper Zero Teardown, Lift the NFC antenna: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
    • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
  6. Flipper Zero Teardown, Pull out the NFC antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Teardown, Pull out the NFC antenna: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull out the rest of the board.
  7. Flipper Zero Teardown, Unscrew the chassis: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    When I did this I had a long screw and a short screw. The long screw was top left. Thanks for the excellent guide!
    Patrick Coyle - crwdns2934203:0crwdne2934203:0
    I also had 1 long and 1 short screw
    Žiga Deisinger - crwdns2934203:0crwdne2934203:0
  8. Flipper Zero Teardown, Seperate the chassis from the top cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the chassis out of the case.
    take the chassis out of the case... well alright... please explain how because it's very much stuck at the side of the USB port :/
    2023 version is different than the 2022?
    remco katz - crwdns2934203:0crwdne2934203:0
    My case is unable to disconnect from the chassis
    Dillon Henault - crwdns2934203:0crwdne2934203:0
    I found out... on some models there are another set of screw on the board with the screen. So you need to carefully remove the first board. Moving the orange plastic stuff helps. Also the boards will still be connected by the battery cable. So you will need to rotate one board over the other gently to access the 2 last screws... epic!
    sebastien.barbieri - crwdns2934203:0crwdne2934203:0
  9. Flipper Zero Teardown, Disconnect the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery by prying the connector with a plastic pry tool and pulling it out.
    • Do not use a metal screwdriver when prying out battery connectors, if you do it may short the battery terminals and cause damage to the battery.
  10. Flipper Zero Teardown, Disconnect the ribbon cables: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to release the locks.
  11. Flipper Zero Teardown, Disconnect the ribbon cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the connectors are unlocked, carefully pull out the ribbon cables.
  12. Flipper Zero Teardown, Unscrew the iButton board: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
  13. Flipper Zero Teardown, Remove the iButton board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screw is removed, carefully remove the iButton board.
  14. Flipper Zero Teardown, Remove the cable from the iButton board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Flathead 1.5 mm Screwdriver
    $5.49
    • To disconnect the flat cable from the iButton board, use a flat screwdriver to carefully release the lock by pulling the latch up, then pulling gently on the ribbon cable.
  15. Flipper Zero Teardown, Remove the cable from the iButton board: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the connector is unlocked, gently pull the cable out of the connector.
  16. Flipper Zero Teardown, Release the battery chassis: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Teardown, Release the battery chassis: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To release the battery chassis, gently rock it back and forth while pulling the two parts apart.
    I'd say it's just a little more than a "gentle rock". There are two tabs. One is visible to the left of the display, through the PCB. The other is hidden under the buttons. I gently released the visible one by flexing it away from the display, and then the other came loose more easily with some gentle encouragement.
    whereami - crwdns2934203:0crwdne2934203:0
  17. Flipper Zero Teardown, Remove the NFC RFID board: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the NFC RFID board, release it from the latches in the sequence shown.
  18. Flipper Zero Teardown, Remove the NFC RFID board: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the board from the latches by pressing on the edge of the chassis near the specific latch in the specified sequence.
  19. Flipper Zero Teardown, Remove the vibration motor: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Teardown, Remove the vibration motor: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the vibration motor.
    Do we have a part number for the motor?
    James Randolph - crwdns2934203:0crwdne2934203:0
  20. Flipper Zero Teardown, Unscrew the lace mount: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • To remove the lace mount, use a PH0 screwdriver to unscrew the short screw that is securing it in place.
  21. Flipper Zero Teardown, Remove the lace mount: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lace mount from the chassis.
  22. Flipper Zero Teardown, Remove the battery: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is attached to the chassis with double-sided tape. To remove it, use a plastic pick to gently peel the battery off the chassis.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  23. Flipper Zero Teardown, Remove the battery: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Teardown, Remove the battery: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the chassis.
    where is the replacement battery? what are the dimensions of the battery?
    Arni Nym - crwdns2934203:0crwdne2934203:0
    This kind of battery is standard, as this device is not a known brand, you will not find a Flipper Zero branded spare part batteries, indeed, it's a standard no-name Li-Po battery that is being used in this device.
    From the picture, we can guess this battery is a standard 3.7V Li-Po battery having a power capacity of 7.77W, so the capacity is indeed 2,1Ah -> so 2100 mAh of capacity.
    Note : we can observe there is a circuit protection (BMS) on this battery, I don't know how this device reports voltage, temp and other battery-related stats but these features may not work properly if BMS of the new battery is not compatible with the device firmware.
    After more research, I found the data sheet of this battery for you as the manufacturer of this device made public a lot of hardware related docs : https://cdn.flipperzero.one/FLIPPER_ZERO...
    I found dimensions are specified in it with other useful information. So I don't know which dimensions you are searching for, there are mentions on page 4 of this doc
    Brendan -
    There is also additional dimensions specified page 5 and also pictures starting page 22.
    This document has been made by the chinese laboratory in charge of thesting the safety of the battery used in the flipper zero device.
    Brendan -
  24. Flipper Zero Teardown, Remove the ribbon cable: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic pick to lift the latch up to unlock the connector.
  25. Flipper Zero Teardown, Remove the ribbon cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the flat cable out.
  26. Flipper Zero Teardown, Unscrew the the button chassis: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  27. Flipper Zero Teardown, Separate the button chassis: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To disconnect the button chassis and the board, press the latch on the side shown below.
  28. Flipper Zero Teardown, Remove the button chassis: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Teardown, Remove the button chassis: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the button chassis.
  29. Flipper Zero Teardown, Disconnect the screen: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock.
  30. Flipper Zero Teardown, Disconnect the screen: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable from the board.
  31. Flipper Zero Teardown, Desolder the screen: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the screen you need to desolder two contacts.
    • Be careful during this step not to accidentally melt or desolder other nearby components.
  32. Flipper Zero Teardown, Remove the buttons: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad)
  33. Flipper Zero Teardown, Remove the buttons: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
    • Release the latches with a flat screwdriver. You need to be careful with the springs under the buttons.
  34. Flipper Zero Teardown, Remove the light guide: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $5.49
  35. Flipper Zero Teardown, Remove the light guide: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flipper Zero Teardown, Remove the light guide: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the light guide out from the inside of the chassis.
  36. Flipper Zero Teardown, Finish: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here you can see all the parts laid out together.
Flipper Devices
crwdns2935283:006/29/22crwdne2935283:0
685 crwdns2915208:0crwdne2915208:0
crwdns2947412:014crwdne2947412:0
I'd say, that long screws requires PH1 screwdriver.
Evge Key - crwdns2934203:0crwdne2934203:0
Agree with Evge, when I read "PH0" I picked mine but they wouldn't quite fit. I had to use a PH1 (1.2 to be exact, according to toolset casing) to be able to unscrew the chasis and get to the battery (I had to only remove and plug back the battery cable to fix my problem)
João Ciocca - crwdns2934203:0crwdne2934203:0
Careful with those screws. They are not great quality and strip easily.
andy cooper - crwdns2934203:0crwdne2934203:0
Yeah, I have run into the same issue. The screw securing my IR/iButton board sheered in half! I cant remove the bottom part since its flush with the socket, but the board seems to be alright without it and is still in place since the chassis supports it. I still need to find a way to get it out :)
SkidFace -
Do you know what kind of these screws are?
Gugo - crwdns2934203:0crwdne2934203:0
Second that about the screws being low quality. Also, if your FZ battery decides it doesn't like you anymore (it shows some 50%ish max), open it (steps 1-4), disconnect it (steps 7-9), and reconnect the battery. And it seems to be something that's gonna be routine, because it happened back in October and again now in December.
When disassembling this time I checked the screws better, and it seems a 2.0 phillips is the best fit for the long screws.
Second the question for what kind of screws are being used? Size/thread?
Enygma - crwdns2934203:0crwdne2934203:0
Am I the only one that ended up with 5 long screws?
geronimo larralde - crwdns2934203:0crwdne2934203:0
My small iFixit toolkit doesn't have the right bits for step 3. PH0 strips the slot on the screw, and PH1 does not fit into the hole. If you have the same tools as me, don't force it, you'll do damage to the screws. Try other screwdrivers.
Tamás Hegedűs - crwdns2934203:0crwdne2934203:0
The IR cover does come out, just pull
Carters lil channel - crwdns2934203:0crwdne2934203:0
there are three golden pins that fall out when you open the clamshell. this doesnt show them or where they go. fml.
Bob L. Phishmann - crwdns2934203:0crwdne2934203:0
Those pins are supposed to be attached to the IR board, you have accidentally broken them off in the disassembly, they can only be soldered back on with a soldering iron/hot air station. You can also just leave them in their respective holes and the press of using the pins, will make them make contact with the board, they will just be loose. Or leave them out entirely, iButton isnt too common in most countries.
Francis -
what do i buy to replace gpio pins 1-8?
Michael S.bush - crwdns2934203:0crwdne2934203:0
What about the wifi module? Is it possible to fix it? I have this kit https://www.sdrstore.eu/software-defined... and the wifi board stopped working after 2 months. Is there any way I can fix it?
Engelbert Jacobs - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 30
crwdns2936753:07crwdne2936753:0 207
crwdns2936753:030crwdne2936753:0 939
crwdns2942667:0crwdne2942667:0 49,745
