Dell Latitude 3310 Teardown
    • Make sure you have a clean desk space with plenty of room to separate components
    • Ensure any devices or peripherals plugged into the laptop are removed and set aside
    • Using the system dialog, power off the computer to prevent data loss
    • Loosen and remove all 10 M2.5x5 screws.
    • Carefully remove the bottom of the laptop by prying it from the hinges and working around the edges.
    • Take caution when removing the laptop hinges as they are fragile and can break
  1. Dell Latitude 3310 Teardown, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the motherboard.
    • Be careful not to bend the pins in the female connector! Make sure to apply equal pressure on both sides of the white male connector.
    • Remove the 4 M2x3 screws at the 4 corners of the battery.
    • Lift away the battery and place it on a flat surface.
    • For temporary storage, place the battery on paper and tape the battery connector.
  2. Dell Latitude 3310 Teardown, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, RAM: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top of the sheet covering the RAM
    • Instructions for removing the RAM are accessible on the sheet that covers the RAM
    • Press the metal rails aside with your fingertips.
    • Take the RAM out and place on a flat surface.
  3. Dell Latitude 3310 Teardown, SSD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, SSD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, SSD: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single M2x3 screw
    • Wiggle the M.2 disk away from the motherboard.
    • The standoff consists of a single M2 screw that can be removed.
  4. Dell Latitude 3310 Teardown, WLAN-card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, WLAN-card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, WLAN-card: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the mounting plate aside
    • Disconnect the antennas
    • Wiggle the card away from the motherboard
    • Rearrange the antenna cables for easier removal of the motherboard later
  5. Dell Latitude 3310 Teardown, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Fan: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the fan from the header
    • Remove 2 M2x3 screws
    • Move the fan aside
    • Take the opportunity to remove dust from the fan
  6. Dell Latitude 3310 Teardown, Motherboard Part 1: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 1: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 1 M2x3 screw and lift DP-cable mounting bracket
    • Move cables aside
  7. Dell Latitude 3310 Teardown, Motherboard Part 2: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 2: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 2: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 M2.5x5 screws
    • Lift the metal brackets.
    • I usually do this by opening the laptop. But be careful so it does not lift and bend the plastics under or back.
    • Then disconnect the DC-cable.
    • You can remove the DC-connector by removing this screw. No markings, but I'd say this one is M2x2.
  8. Dell Latitude 3310 Teardown, Motherboard Part 3: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 3: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 3: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Diconnect makred cables. Make sure to lift up locking tabs with a plastic tool. CMOS and speaker cable are disconnected by pulling on the white connector on the cable.
    • Remove 3 M2.5x5 screws and lift the metal hinge.
    • Remove 2 M2x5 screws that hold metal bracket over USB-C connector.
  9. Dell Latitude 3310 Teardown, Motherboard Part 4: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 4: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Motherboard Part 4: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 M2x5 motherboard screws
    • Remove 2 M2x2 I/O-board screws
    • Lift and move aside motherboard and I/O-board
    • Place on anti-stat mat or similar surface
  10. Dell Latitude 3310 Teardown, Speakers: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Speakers: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3310 Teardown, Speakers: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can simply lift away the speakers and carefully wriggle out the cables
    • I disconnected and removed the MB (motherboard) to KB (keyboard) cable and MB to TP(trackpad) cable.
    • CMOS battery is stuck to frame with glue. The last cable goes to the keyboard that is hard mounted to the frame as well.
  11. Dell Latitude 3310 Teardown, Trackpad: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 6 M2x2 screws
    • Move the trackpad aside
    • The keyboard is hard mounted to the armrest.
    • You should be able to lift the armrest up like you open up the laptop and remove it from the screen.
    • The screen can be open by prying all around the edge and then remove 4 M2x2 or smaller screws to replace the LCD screen.
OskyEdz
crwdns2935283:009/21/21crwdne2935283:0
410 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 2,692
