My Cycliq Fly6 CE Gen3 is less than 1.5 years old and about a month ago its battery stopped taking a charge. When plugged into power, the Fly6 LEDs illuminate red like it is charging, but it refused to charge itself to 100%. When checking the battery charge using the Cycliq app, it shows the Fly6's battery charge is stuck at 18%. Now 17 months old and barely off warranty, I logged a ticket with Cycliq and the best they would offer was 20% off a new replacement unit. Why would I reward Cycliq by purchasing another light at full retail price if I can only expect 17 months of usage? With that, I decided I was going in and I found the repair effort was rather easy.
The housing is held closed with four crosshead screws, each hidden behind little rubber bungs that ensure the unit is watertight. Screw locations are shown in picture 1, dig out screws using a spare pentalobe screwdriver (picture 2), and remove screws using a Philips #00 screwdriver. A paper clip could also work for picture 2.
Turn the light on it's side (picture 1), peel back the sticker (picture 2), and open the housing (picture 3).
Unplug the battery and set aside (picture 1) to test its voltage.
Rather than test the voltage, the first time I unplugged the battery I immediately plugged it back in, powered it up, and found it had 100% charge.
Seconds prior to completing the above task, the battery had been stuck near 18% charge for weeks. Exposure to cold weather and potentially moisture at the battery connectors potentially played a role in this light's temporary demise.
Place some dielectric silicone compound with a pentalobe tool (picture 1), place grease on top of female battery connector leads (picture 2), and press male battery connector on to female leads.
If detaching/reattaching the battery connectors or greasing the battery connectors improved your light's function, repeat steps 1 through 3 in reverse. If not, consider replacing your battery as shown in step 5.
Remove foam covered plastic caps from ends of battery and save for later (picture 1). Replace existing battery (picture 2) with equivalent. To install new battery, you may need to cut wiring harness from existing battery and solder it to new battery.
Where are equivalent batteries available? Especially the ICP6/25/50-2 pack would be great, but individual 602550's would be okay too. Several eBay & other knockoff sites list 602550 batteries, but they all have 1/3 capacity (500-600 mAh vs. 1000 per battery for the Fuji).
My light didn't need a battery, it just needed dielectric grease on the leads and connector. Does your battery have physical damage? What leads you to believe the battery requires replacement?
Good article. I’ve tried to get a new battery but cannot find one any ideas where to get one from
@bobm85679, I'm sorry, but I don't know where to source a replacement battery. If the battery in my light requires replacement, I might try repurposing old vape batteries.
Are you sure your existing battery requires replacement? The battery should likely last between 500 and 1000 cycles. As discussed above, dielectric silicone compound makes and preserves a better connection between the battery and the light's PCB, something in my opinion should have been included from the factory for a device that was designed to be used outside and cycle through different temperatures.
The battery appears to be specially made for Cycliq. It comprises 2 cells running in parallel - a bit naff. If you can find a thin Lipo cell 50*25*5mm you could also run them in parallel. I haven't had any joy finding a solution either.
@scouser58262, thanks for contributing this. Seems Cycliq wanted to boost the battery amperage by running the cells in parallel? Seems odd they didn't go with a single bigger battery?
In my opinion, Cycliq should have picked a battery system with an even greater amperage as I've noticed the light occasionally shuts off when the phone app connects to it via Bluetooth (and the light and camera simultaneously running). To avoid these shut-offs, I turn off video recording and the LED light if I expect to spend a longer time configuring the light/camera in settings while using Bluetooth. I expect my strategy will no longer work as the battery ages and the peak amperage it can provide declines.
