crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Breville Smart Kettle BKE825crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Breville Smart Kettle BKE825 Teardown, Breville Smart Kettle Specs: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Breville Smart Kettle Specs: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Breville Smart Kettle Specs: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This 1.7 capacity kettle knows the ideal temperature for tea or coffee. 5 varietal settings brew at the right temperature for Black, Green, White and Oolong Tea and French press coffee.
    • Product specifications:
    • Dimensions: 23.2 x 156 x 25 cm
    • Construction Materials: Stainless Steel
    • Capacity: Large 1.7 L / 7 cup capacity
    • Settings: 5 temperature settings (Green Tea, White Tea, Oolong Tea, Black Tea, Coffee).
    • The Kettle has 2 major components - The electric base and the water compartment. The guide will follow individual teardowns for each compartment - starting with the main water compartment.
  2. Breville Smart Kettle BKE825 Teardown, Kettle bottom removal.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Kettle bottom removal.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Kettle bottom removal.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin teardown by flipping the kettle upside down. You will see 3 small triangle head security screws (shown in red circles) holding a plastic casing for the base.
    • Remove each screw with a small triangle head screwdriver.
    • The plastic casing should then easily lift off base.
  3. Breville Smart Kettle BKE825 Teardown, Heat coil Sub-Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Heat coil Sub-Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Heat coil Sub-Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now we will remove the heat/steam sensor.
    • Use a small phillips head screwdriver to remove 5 screws (shown in red circles).
    • Use the wire cutters to cut any necessary wires holding the sensor in place.
    • Once all these items are free, the sensor should be easy to remove from base.
  4. Breville Smart Kettle BKE825 Teardown, Side View Ports: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Side View Ports: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The plastic view windows on the sides of the kettle can now be pushed into the kettle to remove them.
    • They are only held in place with the rubber seal surrounding them and are fairly easy to push in.
  5. Breville Smart Kettle BKE825 Teardown, Removing the Debris Filter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Removing the Debris Filter: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Removing the Debris Filter: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the debris filter from the kettle by lifting the tabs on the bottom and pulling the whole assembly out.
    • The filter grill can also be removed from the housing by sliding it out upwards.
  6. Breville Smart Kettle BKE825 Teardown, Removing the Lid: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Removing the Lid: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Removing the Lid: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now we can start to disassemble the lid on. Start by opening the lid and removing the rubber gasket around it
    • The whole lid and hinge assembly can now be removed with these 3 screws.
    Hi, Soft Lid spare part how to find, Kettle working well, because of loosen screws Soft Lid plastic top not any more close the top. Any possibility to find only this part to keep continue the kettle afain ?
    Bülent ERBAŞ - crwdns2934203:0crwdne2934203:0
  7. Breville Smart Kettle BKE825 Teardown, Lid Components: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Lid Components: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lid can now be disassembled further by pressing the clear piece up and out of the lid body.
    • All of these lid components require no tools as they are press-fit or held together with adhesive.
    Where can I buy the parts?
    itamar1981z@gmail.com
    איתמר ציון - crwdns2934203:0crwdne2934203:0
  8. Breville Smart Kettle BKE825 Teardown, Removing the Handle: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Removing the Handle: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the 3 screws from the hinge are removed, the handle assembly can be pulled off easily.
    • The smaller black piece of plastic that is below the handle can now be pried off with a screwdriver or a chisel.
    • This small piece is only there for aesthetics and is glued on with adhesive.
  9. Breville Smart Kettle BKE825 Teardown, Removing the Heat Disperser: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville Smart Kettle BKE825 Teardown, Removing the Heat Disperser: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the ring on the inside of the kettle is done by bending back the three tabs holding it down with a screwdriver or long needle nose pliers.
    • The ring can then be lifted out.
  10. Breville Smart Kettle BKE825 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To start the tear down for the electrical kettle base component, turn it upside down and locate the 3 triangle head screws (circled in red).
    • Remove these 3 screws with a small triangle screwdriver and lift off the plastic casing.
    how do i get the small triangle head screw driver!
    steve ramser - crwdns2934203:0crwdne2934203:0
  11. Breville Smart Kettle BKE825 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, remove the 2 lower phillips head screws (circled in red) with the small phillips head screwdriver.
    • Lift off the base plastic casing for the heating element. You will notice that the power cord is still threaded through the lid.
    • Cut the cord with the wire cutters and remove it from casing.
    These screws are not there on my kettle, but clearly there needs to be more done to release the base. The rubber feet seem firmly held in but gentle persistent wiggling with a flat head screw driver on the inner face of the rubber at the fix point and it pops out of the hole, below which there are screws.
    However they are very deep and appear to misaligned to the holes I have revealed. I suspect that they are not part of the process to remove the base.
    Any advice?
    Model is BKE825 /A (for Australia I assume)
    Ian Addinsell - crwdns2934203:0crwdne2934203:0
  12. Breville Smart Kettle BKE825 Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew and remove the 6 phillips head screws (displayed in the red circles). 2 of the screws will be apart of a bracket fixture. Once removed, also remove the small plastic bracket.
    • To remove the PCB (Printed Circuit Board) you will need to use 2 long, thin tools to press a latch - we used 2 screw drivers. Apply inward pressure at the inserts shown on image (red arrows) and pull PCB plug outwards at the same time. With some applied force, the PCB should eventually release.
    • With the wire cutters, cut any necessary wires that connect the heating component to the plastic casing.
    • Once all these fixtures are removed, the heating element should seperate from the plastic base.
    Hi @arthurshi
    Thanks for (helping with) this guide!
    I'm trying to disable the annoying beeping of the Breville BKE825. Is the little round thing (which is connected to a read and a black wire (see image), the piezo beeper? Can I stop it from beeping without completely cutting it off?
    https://guide-images.cdn.ifixit.com/igi/...
    Any tips welcome. :-)
    Ralf
    Ralf Weinand - crwdns2934203:0crwdne2934203:0
  13. Breville Smart Kettle BKE825 Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the button component you must unscrew 1 x phillips head screw from the plastic base (shown in red circle).
    • The button subassembly should separate from base of kettle for further teardown.
  14. Breville Smart Kettle BKE825 Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville Smart Kettle BKE825 Teardown: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next step is to remove the Stainless steel frame from the plastic mould
    • As part of the steel frame, there are 9 extended thin tabs (red circles) that wrap around the plastic mould to hold it in place.
    • Lift these tabs vertically and then separate the metal from plastic.
    • You will find thin rubber protection between the layers in areas where required. Separate them also.
  15. Breville Smart Kettle BKE825 Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, we will disassemble the button assembly by putting each component apart.
    • Begin by removing the metal button rivets.
    • Afterwards the plastic padding should be easily pulled off.
    • The clear plastic female rivets should twist out of place and also be removed easily.
    • This completes the teardown for the kettle base.
  16. Breville Smart Kettle BKE825 Teardown, Breville Smart kettle - all components: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Final layout once teardown is complete showing all components
Jye Brien
crwdns2935283:010/09/18crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
Excellent post. Expecting more posts like this. Talking about electric kettles I would like to mention here about nestofbest.com which gives the ten best electric kettles that will be suitable for kitchen.
Erica Fernandes - crwdns2934203:0crwdne2934203:0
This teardown is missing an clear image of the PCB; the brains that controls the kettle?
Is there a digital temperature sensor? Or is the temperature controlled by bi-metallic strips?
Chris W. - crwdns2934203:0crwdne2934203:0
Need repair manual for for breville kettle vjk956.
saeed paloba - crwdns2934203:0crwdne2934203:0
The temperature must be signalled via those 2 thiner wires (thin white and blue wires in step 12). The most fragile parts here are those most frequently pressed micro-switches - power and keep warm in my case. Will have to re-solder them carefully, since the logic started to interpret clicks a bit randomly, like you push power - it doesn’t work, push a bit harder - it starts to change temperatures. Switches are factory soldered as deep as possible, thus will need to take extra care unsoldering them working each contact with some wooden stick and running fast between contacts with soldering iron…
Still fixing - crwdns2934203:0crwdne2934203:0
All are very clean , thank you .
Eddie Pieterse - crwdns2934203:0crwdne2934203:0
I have a similar Breville kettle and a very small amount of water was spilt on the base. It now is not working when plugged in. I was able to open up the base following the directions, and everything looks totally dry. However, I am thinking there must be a moisture sensor that has been triggered, and wondering if it is permanently disabled now or will it work if I leave it to completely dry?
Thanks for any advice...
Greg Johnson - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 185
crwdns2942667:0crwdne2942667:0 17,555
