crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0bread makercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Bread Maker Teardown, Bread Maker teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Toast Select Luxe adjusts the toasting time for each type of bread. 'Lift & Look' to check if it's done. Press 'A Bit More' and to give it just that… a little bit more. Follow toasting progress with the LED countdown indicator. Crafted with brushed stainless steel in premium metallic finishes and chrome accents.
    • VARIABLE BROWNING CONTROL Toast to your ideal browness level while the LED indicates your browning progress.
    • INNOVATIVE AUTO FEATURES 1-Touch 'A Bit More' and 'Lift & Look' functions are derived directly from your feedback and makes for flawless toasting.
    • EASY CLEANING No need to ever lift when cleaning. Just pull out the front crumb tray and tip it into the dustbin.
    • Construction Materials:Brushed stainless steel body with back-lit buttons.
    • Dimensions (WxDxH):8.2" x 7.9" x 13.4"
    • Power:1000 Watts Voltage:120Volts, 60Hz Settings:6 Bread Settings: Wholewheat, White, Bagel, Waffles, Pastries and English Muffins 4 Functions: 'Lift & Look', 'A Bit More'/Reheat, Frozen and Cancel
  2. Bread Maker Teardown, Remove the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown, Remove the screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From the bottom, the bread maker has 4 screws securing two pieces of the shell.
    • Time to cut it open!First thing’s first, let’s turn over the machine, there are 4 screw in sight, therefore a screw driver is up.
    • Take a closer look after removing the screws on the bottom, we can see there are still 4 plastic pads and silicon circles that are waiting to be taken away.
  3. Bread Maker Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You might notice that the shells are not apart yet, but take a closer look, it’s already loose.
    • This is when you flip it upside-down again, find the very botton on the side and take it off, a simple twist and pull will do the work.
  4. Bread Maker Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Time to get our first glimpse inside this bread maker.
    • To take off the mainboard, you need a screw driver to remove those three screws.
    • Unplug those wires highlighted in the photo.
    • Ta-da! You successfully removed the mainboard!
  5. Bread Maker Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To teardown the mainboard from the other side, this is what you have to do--
    • Unplug all wires connected to it.
    • picture 2 shows how it should be like after you did the instruction above.
    • All you have to do now, is to take away the mainboard along with the metal chip beneath it.
  6. Bread Maker Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the last step of taking the shell apart--cut the wire.
  7. Bread Maker Teardown, dismiss the disk: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown, dismiss the disk: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown, dismiss the disk: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, take off the screws like shown in the picture.
    • Then you will see a board also secured with screws——repeat your last move.
    • There you have a small board!
  8. Bread Maker Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Same spot, same move—— remove three screws on top of the disc.
    • Then there you are—— a small disc!
  9. Bread Maker Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let's move on to the inside of the shell, shall we?
    • There are so many screws on this thing, huh? Let's just screw them off and take out the small board.
  10. Bread Maker Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Same old same old. Screw them off and take out the transparent plastic lid.
  11. Bread Maker Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • bend the metal sheets shown in the picture.
    • Then you will have those small components.
  12. Bread Maker Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bread Maker Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unbend the sheet metal in p1&2.
  13. Bread Maker Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bread Maker Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, take off the clips in p1&2.
    • Generated by all the steps above, you can pull out this metal wire easily.
  14. Bread Maker Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • However, the last step is a lot more difficult, this is to seperate its silver machine case with its black plastic base.
    • This step requires specialised tool, for any other normally seen screw drivers/tools will easily bend the metal inside.
    • Therefore, if not necessary, don't teardown this part without specialised tools.
  15. Bread Maker Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All components of a bread maker.
Diana S
crwdns2935283:004/24/20crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
Je ne sais pas de quelle origine vient l'appellation "Machine à pain" pour cet appareil, mais en France on appelle cela un grille-pain. L'appellation "Machine à pain" est destinée à un appareil qui permet de pétrir et cuire le pain ce qui est franchement différent.
Gilles Guérin - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 487
