Remove the plastic back and the exposed battery.
Do not forget to remove sim- and SD-cards
Use a torx t5 to unscrew all screws. This will be the first and last time you'll use a screwdriver with this device.
Use a plastic opening tool or spudger
Pry around the side to release the backframe from the middleframe
To free the main board, remove the connector and antenna-cable
Tilting the main board will reveal this connection
Use a plastic spudger to open the lock
Carefully pull the flex cable out of it
crwdns2935267:0crwdne2935267:0Tweezers$4.99
At the bottom, use a pair of tweezers to remove the yellow tape from the connector
Use a plastic spudger to unlock
Pull the flexcable out carefully
Next, use a platic spudger to remove the flex cable from its connection
Use a spudger to remove the bottom-plate from the frame.
Make sure the antenna cable isn't attached to anything except it's socket
Let the remaining heat at 95°C for about 3-5 minutes to soften the adhesive
Use an opening tool to pry at the top, between your digitizer and the middleframe
Open it from the top, your digitizer-flex runs at the bottom
To remove the LCD, remove the sticker on the back of the midframe. It conseals the LCD-flex
Remove the LCD by pulling the whole cable through the midframe.
All done
I hope you enjoyed it as much as I did
Great Manual.. it work fine! thanks,,
