How To
Everything You Need to Know About DFU Mode for iOS Devices
Hands holding an iPhone 7 in DFU Mode
This post was originally published May 2020it was updated in June 2025.
The DFU Mode in iPhones and iPads is an emergency tool that’s not designed for most people to ever see. It’s hard to activate, and the screen stays blank when you finally manage to trigger it. And yet this obscure tool is essential for resurrecting a dead iPhone, or rolling back an unwanted iOS update.
Here’s what DFU Mode is, what it’s really for (and not), and how to get into it. A quick note: wherever we refer to an “iPhone” or “phone” in this post, you can also assume it applies to an iPad.
What is DFU?
When you power on your device, the Apple logo usually appears. A short while later, the iPhone is up and running, asking for your passcode. That seemingly simple procedure obscures several other processes happening in the background.
One of these is the loading of the bootloader, called iBoot, which in turn loads iOS. The bootloader is important, because it governs what can be loaded on the device, enforcing Apple’s rules and security restrictions. In order to jailbreak an iPhone, for example, you have to crack the boot loader so you can load a modified version of iOS.
But what if the iPhone won’t start up at all? In that case, there are two options: Recovery Mode, and DFU, or Device Firmware Update Mode. Both of these are activated by tapping out a combo of button presses on the handset itself right after powering it up, and both are designed to let you hook your dead or malfunctioning iPhone up to a computer via USB, even when the iPhone won’t boot into iOS. From there you can reinstall iOS, or carry out other rescue operations, as detailed below.
DFU vs Recovery Mode: Which One Do You Need?
Recovery Mode puts the iPhone into a state where it can be plugged into a Mac or PC, from which you can push a fresh version of iOS onto the device. It loads just the bootloader, a.k.a. iBoot, then waits for you to do the rest. Because it is using the iPhone’s bootloader, it can still make sure you don’t install any unauthorized software onto the device. And importantly, the Recovery Mode can be patched and updated by Apple when necessary.
Recovery Mode is easy to get into, if you have a computer and a Lightning cable nearby.
Recovery Mode is the officially-supported way to recover your iPhone, and it is easy to reach once you know the right steps to follow. You’ll know you’re in Recovery Mode because you’ll see a graphic telling you to hook the iPhone up to a computer, in order to complete the recovery.
DFU Mode is more powerful than Recovery Mode, and is unsupported and undocumented for us, the end user. It lets an iOS device connect and talk to iTunes (or either the Apple Devices app on Windows or its Finder equivalent in macOS Catalina or later), without loading the bootloader, or iOS itself. As its full name— Device Firmware Update Mode— suggests, the mode is used to update the actual firmware of the device, mostly to install a boot loader.
DFU Mode is hard to enter, requiring convoluted sequences of button presses to enter. Even when you reach DFU Mode, the screen remains blank.
Unlike recovery mode, which can be updated with a software update, DFU is burned into the hardware, and cannot be altered. But it’s a powerful tool. Because it works at a lower level than Recovery Mode, DFU lets you do things not allowed in Recovery Mode.
When to use it
Screenshot of Mac showing a phone in DFU Mode.
What it looks like when an iPhone in DFU Mode is hooked up to MacOS (Catalina and later). Confusingly, it uses the phrase “recovery mode,” although that’s a different thing. Apple would really rather you not muck around in this mode.
There are two good uses for DFU Mode. One is to repair an iPhone or iPad that has a corrupt bootloader. This is done by accessing DFU Mode, and then hooking it up to a Mac or PC to install the new software.
The other main use for DFU is to downgrade to an older version of iOS. For instance, if you are running a beta of a new version of iOS, you cannot downgrade through a Settings toggle or hooking up to a computer. That’s because the iBoot bootloader will only let you install the most recent version of iOS for your device (that is, it only allows higher version numbers than what’s on the phone already). DFU doesn’t have this restriction. The version of iOS being installed still needs to be signed by Apple, but that’s the only requirement.
These days, Apple stops signing iOS versions very soon after updates are released, so you have a short window to downgrade. Sorry to say, but there’s no way to restore that 1st-gen iPad mini to iOS 8, where it still ran fast enough to use.
DFU mode was also an essential part of jailbreaking. While some early jailbreaks involved little more than clicking on a link, many of them required DFU Mode. That door was closed in iOS 6, but resurfaced with the checkm8 jailbreak for older iPhones.
How to enter DFU Mode on your iPhone or iPad
The procedure for entering DFU Mode varies with each new series of iOS devices, but involves pressing the right hardware buttons in the right order, usually for an exact number of seconds. It’s frustrating, because you’ll often end up just restarting your iPhone or iPad, or entering Recovery Mode instead. But persevere and you’ll get there.
A video how-to on getting into DFU mode, for iPhone 7 and earlier.
Caution: If you haven’t upgraded your OS to the latest compatible version, then a DFU Restore will upgrade your device to the latest signed version of iOS compatible with your device. This is not reversible once completed.
Make sure to back up your device to iCloud or Finder (macOS 10.15 or later), the Apple Devices app (Windows 10/11), or iTunes (macOS 10.14 or earlier) before starting the DFU Restore. Do NOT skip this step!
Note on the term Top/Side button below:
  • Side button: The button on the right edge of every iPhone 6 and later (including all Face-ID iPhones and the 2nd/3rd-gen iPhone SE).
  • Top button: The single button on the top edge of:
    • All iPads without a Home button
    • iPhones with home buttons (6s and below, SE 1st gen) and every iPod touch
The function is identical: it’s the Sleep/Wake/Power button you press to lock the screen or turn the device on/off.
iPhone 6s and below, iPod touch 6th gen and below or iPad with Home button
  1. Connect the device to a computer using a USB cable.
  2. Hold down both the Home button and Lock button.
  3. After about 8 seconds, release the Lock button while continuing to hold down the Home button.
    • If the Apple logo appears, the Lock button was held down for too long.
  4. Nothing will be displayed on the screen when the device is in DFU mode. If open, iTunes will alert you that a device was detected in recovery mode.
    • If your device shows a screen telling you to connect the device to iTunes, retry these steps.
iPhone 7, iPhone 7 Plus or iPod touch 7th gen
  2. Hold down both the Side button and Volume Down button.
  3. After about 8 seconds, release the Side button while continuing to hold down the Volume Down button.
    • If the Apple logo appears, the Side button was held down for too long.
iPhone 8 and later or iPads without Home button
(iPhone 8/8 Plus, iPhone X to 16 series, iPhone SE (2 & 3), iPad Pro/Air 4-5, mini 6, iPad 10th gen, etc.)
  2. Quick-press the Volume Up button
  3. Quick-press the Volume Down button
  4. Hold down the Side button until the screen goes black, then hold down both the Side button and Volume Down button.
  5. After about 5 seconds, release the Side button while continuing to hold down the Volume Down button.
  6. Nothing will be displayed on the screen when the device is in DFU mode. If open, iTunes will alert you that a device was detected in recovery mode.
Exiting DFU Mode
To exit DFU Mode, simply force restart your device.
  • For iPhone 6s and below, iPod touch 6th gen and below or iPad with a Home button: hold the Home button and the Lock button until the device reboots.
  • For iPhone 7, iPhone 7 Plus or iPod touch 7th gen: hold down the Lock button and Volume Down button until the device reboots.
  • For iPhone 8 and later or iPads without Home button: quick-press the Volume Up button, then quick-press the Volume Down button, then hold down the Lock button until the device reboots.
Now that your device is good as new and all your apps are downloading, give your device a few days to recalibrate. Please note that recalibration can take some time and we recommend fully charging your device then letting it fully discharge a couple times before declaring the problem officially fixed or not.
