Nintendo Switch Lite 스크린 교체
Nintendo Switch Lite Screen Replacement, Heat the left edge: crwdns2935265:00crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Heat the left edge
  • Flip the frame over so the screen is facing up.
  • Heat an iOpener and apply it to the left edge of the screen for two minutes.
  • Alternatively, you can use a hair dryer on the Low heat setting.
  • If you're using a hair dryer, only heat the screen a few seconds at a time or you may warp the plastic shell.
스크린이 위를 향하도록 프레임을 뒤집으세요.
iOpener를 가열하고 2분 동안 스크린 왼편 가장자리에 적용하세요.
헤어드라이어, 열선총 또는 열판을 사용할 수도 있지만 프레임을 과열하지 않도록 주의하세요.
[title] Heat the left edge
[* black] Flip the frame over so the screen is facing up.
[* black] [guide|25705|Heat an iOpener|new_window=true] and apply it to the left edge of the screen for two minutes.
- [* icon_note] A hair dryer, [guide|151116|heat gun|new_window=true], or hot plate may also be used, but be careful not to overheat the frame.
+ [* icon_note] Alternatively, you can [guide|157348|use a hair dryer|new_window=true] on the ***Low*** heat setting.
+ [* icon_caution] If you're using a hair dryer, ***only heat the screen a few seconds at a time*** or you may warp the plastic shell.
