REVVL Plus Display assembly (with frame) Replacement
REVVL Plus Display assembly (with frame) Replacement, Removing the motherboard: crwdns2935265:00crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  • Remove two Philips screws on either side of the rear-facing camera.
  • Like the charging port assembly, the motherboard is held in with clips as well. Use the same process to remove the motherboard.
  • The front and rear cameras are adhered to the frame and connected to the motherboard with flex cables. As you lift the motherboard, check underneath and disconnect the cameras from the motherboard with the flat end of a Halberd spudger if necessary.
