REVVL Plus Display assembly (with frame) Replacement
REVVL Plus Display assembly (with frame) Replacement: crwdns2935265:00crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  • Remove one Philips screw from the charging port assembly.
  • The circuit board is held in by two clips: a plastic clip on the left side and a metal clip on the right side.
  • To remove the circuit board, insert a plastic opening pick between the circuit board and the plastic clip, and gently bend the center of the circuit board upwards to disengage it.
  • Using an opening pick, gently detach the weak adhesive underneath the circuit board and remove.
