iRobot Roomba 890 Charging Contacts Replacement
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Devin Steiblin
crwdns2935283:003/28/22crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Petersen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-3, Petersen Spring 2022crwdne2935289:0
UMASSD-PETERSEN-S22S1G3
crwdns2936753:030crwdne2936753:0 130
crwdns2942667:0crwdne2942667:0 5,713
