iRobot Roomba 870 Side Brush Motor Replacement
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870 Side Brush Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
Karthik Padmanabhan
crwdns2935283:004/17/17crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S14-G3, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S14-G3, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S14G3
crwdns2942667:0crwdne2942667:0 4,170
