iRobot Roomba 870 Bumper Sensor Replacement
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 870  Bumper Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
crwdns2935229:013crwdne2935229:0
Jacob Lindberg
crwdns2935283:004/19/17crwdne2935283:0
449 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S14-G3, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S14-G3, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S14G3
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - crwdns2934203:0crwdne2934203:0
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - crwdns2934203:0crwdne2934203:0
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 8,662
