The iRULU AX106 is a android tablet and due to the tablet being released in 2012 there is many things that will need to be replaced over the years. This guide requires the use of a soldering iron and also the use of a screwdriver. In this replacement guide the user will learn how to disassemble the iRULU down to the logic board, and replace the battery.
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, gently disconnect the cable connectors from the circuit board.
Completely separate the screen and case.
The battery is located right above the logic board, and can be identified as a large flat black rectangle.
Use the plastic opening to scrape away the glue that is holding down the battery.
crwdns2935267:0crwdne2935267:0Desoldering Pump$3.99
You should see that the battery is connected by 2 wires, one black and one red that lead to the logic board.
Heat up a soldering iron and melt the solder that is connecting the battery to the logic board.
Completely remove the battery from the device.
Insert the new battery and re-solder the corresponding wires to their respective locations.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Where do you get a new battery
The batteries should be in a holder, not have to unsolder and solder. Most people do not have a soldering iron.
Is that a iPad battery?
