iPod Nano 4th Generation Display Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace a broken display.
crwdns2944105:0crwdne2944105:0
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
Remove the hold switch slider from the top of the Nano.
Remove the two angled Phillips screws from the two corners of the display retainer.
Be sure to use a good phillips #00 screwdriver here, or you run the risk of stripping the very small screws.
The screws were covered with the adhesive. They were very difficult to remove.
I RUINED the hold switch! I accidentally broke the cord. 0_o The directions were kind of unclear.
crwdns2936937:0bodiegcrwdne2936937:0
Step 12 is misleading as it does not show to remove the screen from the metal frame.
Sorry guys, but the explanations are really bad. Go onto youtube and watch it. This site misses heaps of steps. I just broke my iPod :(
Like others have noted, screws are covered in adhesive and difficult to remove. Take extreme care to not strip the heads. I'd suggest using a very small flathead to scrape some of the adhesive off before attempting to remove the screws.
a 1mm slotted screwdriver will work in a pinch, but be carefull and make sure you get the angle just right
The tools list doesn't say you need an iPod opener to, nor does the parts list day you'll need a new click wheel, though this is called ”...click wheel REPLACEMENT”. I don't get the feeling these are very trustworthy instructions, ESPECIALLY after having read other comments. I'd say BEWARE, and look at a variety of resources to get a much more comprehensive picture.
Actually, the screws are not aligned with the edges of the iPod, which means that you must not try to unscrew them vertically. If you do there is a good chance that you damage the head of the screws. Thus look carefully with a torch to see at what angle you have to unscrew them.
Actually, the screws are not aligned with the edges of the iPod. That means that if you try to unscrew them vertically, there is a good chance that you damage the head of the screws. Thus, look carefully with a torch to see exactly at what angle you need to unscrew them safelly.
Everything was good up to this point. I could barely see the screws and ended up stripping them. Just gave up at this point and threw the
Ipod on the ground and stomped on it.
I agree with several other contributors here, that a properly sized flat screwdriver *that is not worn* held at the correct angle is a better option than a phillips because the screw head is filled in with adhesive tape. BEWARE: The screws on the top and bottom outer edges are not parallel to the case. They are offset by 25 or 30 degrees, with the tips of the screws pointing out towards the outer edge of the case with respect to where the heads are. Use something to get magnification so you can really see how your screwdriver fits, and whether it’s engaged. An undamaged and properly sized standard screwdriver held in the appropriate orientation will readily remove the top and bottom side screws without stripping and with very little force. Feel for engagement — press the screwdriver in just enough to get past the adhesive. Not much torque or pressure is required — just a good fit. You must have the right tools to do this job successfully, and look under high magnification. Align your screwdriver!
In accordance with another source, I have bought online and used a Phillips #0000 screw driver, which worked pretty well here. It costed me only $2 .
Screws are inserted under an angle. Would suggest to use a jeweler’s magnifying glass to check the angle before sticking any screw driver in there.
BEFORE REMOVING THE SCREWS spend all the time necessary to remove thoroughly the very sticky gunky glue from the screws, using a needle and gently scraping off absolutely every bit of glue on and around the screw. If you don't you will flatten the screws and this would make your ipod almost impossible to open. Once the glue is removed, and with a small enough screwdriver, it should NOT require force. Do NOT use use force!!! Or you will ruin the screws.
Insert an iPod opening tool between the outer case and the display retainer.
Use the tool to slide the display assembly out of the case slightly.
I found I had to gently pry the retainer open with a craft knife (xacto knife?) as the plastic opener tool was too blunt or soft to get any purchase...
My nano had a "swollen" battery which wedged the LCD between battery and front glass. As a result, this step didn't work, I couldn't pull out the TFT and botched case, TFT and TFT frame until it came out. Telltale sign was a display that looked like there is a water between glass and LCD. The other nanos I've opened didnt have this problem and came out effortlessly, so if yours is stuck, don't feel bad, there's not much you can do!
What to do if the upper metal base (which is fixed to the circuit with 2 screws) came off when extracted?
Which side can I anchor to force the display to exit?
I had the BAD idea of following the Parts Plus Pods tutorial for this step and he's quite a brute and removes the aluminium part then pulls it out then pulls again like a brute on the fragile metal bracket which tends break while damaging the button AND breaking the cable (all of which I unfortunately did). So this step is very important. The metal bracket that hold the button (under the aluminium display retainer being pulled on the photo) has to stay attached to the metal bracket under it.
"Do not rotate the display retainer about the top edge of the display" is a confusing statement. The axis of rotation mentioned is width axis, the only one you can rotate around. It's the rotation of the aluminium display retainer that happens when you pull exactly like on the picture. So keep pulling it EQUALLY on both sides (front/back of the device), the idea being to pull it like a drawer. Otherwise you risk breaking everything like I did.READ BEFORE DOING THIS STEP As soon you pull this up a bit, I recommend you do step 8 right away, which is ungluing the switch to free it and prevent either the hold switch or its cable from breaking in later steps. This is by far the biggest flaw of this guide. It is unfortunately not written for maximum damage minimisation. I broke the cable and the switch so please unglue the switch (as in step 8) so that when you pull the LCD screen you don't risk breaking the cable. If it breaks it's game over, so be careful!
Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
I have several problems in taking it out. I don't know if it is dued to the glue that the iPod has inside. Could you help me. Thanks
instructions say 5" (inches) it really means 5mm
No it says .5" as in 0.5" = half an inch. But in your defence they should have written it more clearly, very easy to miss that dot, and yes pulling 5 inches would destroy the cable for sure!
crwdns2936937:0pedalsandpickscrwdne2936937:0
If you're gonna repair the way you read it will get you nowhere: the text reads .(as point)5 inch. Which is about 12mm.
you didn't need to be snarky
The glass panel can be very difficult to get moving requiring a lot of downward force. I have found good old fashioned spit to be very useful here.Just lick both thumbs and rub on fingers until just sticky enough.
This willl move the glass.
READ BEFORE PULLING THE SCREEN This is step where you can easily break your second cable! (after the hold button cable from earlier steps.) DO NOT USE FORCE. Pull just enough like on the photo.
In my case, the battery was swollen (visible on the screen when it's off, it looks like there's water between the screen and the glass cover). I suspect as well that the LCD was glued against casing. It was beyond hard to pull the screen out. I ended up breaking the LCD screen by prying inside it instead of in front of it with a cut out piece of that transparent hard plastic everything is sold in (makes a great makeshift prying tool otherwise to unglue the cables gently). I don't know if an LCD screen can be removed without breaking it if he battery is very swollen. A way to avoid that in future is keep replacing your battery early enough and definitely at the very first signs of swelling. It will allow you to pull the screen super easily and not break it every time. -
With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
I found the adhesive (or fit) quite strong. Pushing on the bottom part of the glass created a small gap at the top, which I could fit a craft knife (xacto blade) into. This made it easier to carefully lever the glass out for me.
I slipped and broke the LCD. So !#^&@@ off. What an absolute bastard of a job!
What is the "rear edge" of the nano? Can this be a bit clearer please? Maybe a video of this step would be a good idea. Then again, since Apple owns this site, I guess that's not gonna happen, is it?
I don't see "rear edge" anywhere in the instructions. I do see "lower edge" a few times and it looks pretty clear to me. I did this repair a couple years ago without much trouble.
You could do all these steps and really mess up your nano. Instead of disassembling the iPod, carefully remove the remnants of the old glass which I assumed you have cracked. With the new glass in hand CAREFULLY sand one edge of the glass evenly. I used my fine grinder on my dremel tool. After assuring a snug fit I removed the adhesive and installed the glass. Looks great and functional and I didn't ruin my iPod in the process. And when I said sand one edge I mean one of the edges that has a "lip" on it. The other lip you can slide right in and push gently down for a nice fit. Do not remove the adhesive until you are sure of a good fit. This is a quick fix for those who are too queezy to take apart their device.
My battery had expanded and pushed out the glass enough for me to peel the glue out like a battery pull tab on a phone so it was pretty easy to remove, but the screen is giving me some trouble. The expanded battery is holding the screen to the frame making it more difficult to remove.
Absolut falsch beschrieben, die Anleitung ist
Grottenschlecht
Lieber Herbert,
schade, dass dir die Anleitung bisher nicht geholfen hat. Stand heute haben bereits 35 andere Nutzer ihr Gerät damit erfolgreich repariert, deshalb wäre es gut zu wissen, was genau bei dir nicht geklappt hat und wo es hakt?
Unsere Anleitungen werden nach dem Wikipedia-Prinzip geschrieben, das heißt du kannst auch selbst jederzeit noch zusätzliche Punkte hinzufügen oder Änderungen vornehmen, die besser beschreiben, was hilft, damit für diejenigen, die nach dir diese Reparatur versuchen, eine noch umfassendere Dokumentation zur Verfügung steht.
To get this right, the important bit is to not just press it IN and also TOWARDS YOU, with a bit of downward pulling grip with your thumbs.
Lift the glass panel out of the Nano.
Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
Be extremely careful while doing anything around the screen. The slightest bit of pressure in the wrong direction and you will be replacing the screen along with the battery. I speak from experience.
I was extremely careful… and, I broke the display! ~ Gah! ~ $18 for a new one on Ebay (half the price if I wanna wait 3-4x as long to purchase from overseas, twice the price if I buy it from this site!) ~ What a bummer! ~ The goal was to fix this for a customer, and instead I created a longer wait & obviously have to pay for the screen I broke. LISTEN TO BRIAN! BE CAREFUL! THE SCREEN _WANTS_ YOU TO BREAK IT! DON’T FALL FOR IT!
Does anyone know where I could get the power button flex cable replacement? I was too extremely careful but the screen has a very precise fit. I is fine when you push the screen into the case but !&&* of a work to pull it out.
THIS SHOULD HAVE BEEN BETWEEN STEP 4 AND 5, no point ungluing the switch this late. The earlier you do this the better to avoid breaking the hold switch cable by puling the screen...like I did...and others here too apparently.
Peel back the Kapton tape covering the display data cable socket.
While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
Continue to carefully hold the socket down while doing the next step. If the cable come off at the wrong angle it can pull the connector away from the board at the base of the screen.
Make sure to ZOOM IN to get this right, this picture is not clear otherwise.
Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
Some of the ribbon is inside the white housing with the lock on, it needs to slide out of the housing. I didn't notice this because everything is so small - be sure not to slide your pry tool right through it.
The display can actually be pulled out slightly further than it initially seems. When you gently pull it up, you'll experience some resistance, which I initially thought indicated it was as far as it could go. But an extra bit of (still very gentle) force can pull it up a few more millimetres, which means the opening tool can fit.
Also, it seemed to me to actually be helpful to lever the cable out of its port before removing the ribbon from the adhesive on the plate, since this allowed better access to the adhesive with the opening tool.
As commenter Brian Campbell wrote on the previous step, it is important to hold down the white cable socket while carefully working the cable loose from the adhesive. Even a small amount of upward force on the display data cable while it is still inside the socket could be enough to tear the socket off the board. Try not to pry up - use a thin, new (undamaged) opening tool to get under the ribbon cable and keep it parallel and as close to the metal plate as possible. It needs to be worked *under* the data cable, not to pry, as the cable just slides straight out the bottom of the white socket.
Instead of that tool which is not fine enough, I strongly recommend using those plastic stiffeners used to keep the collars of shirts straight, OR cut out a pointy shape from the hard transparent molded plastic used in commercial packaging, that made a great GENTLE and efficient prying tool for these glued cables.
Pull the display out of the Nano, minding the hold switch cable that may get caught.
WATCH THE HOLD SWITCH!! Be *sure* it is disconnected before pulling out the screen! (I've made that mistake too many times :P)
disconnected from what?
I never saw where it was connected to!
@fredrodolf Step 8: ungluing the hold switch, which really is best done much earlier between step 4 & 5, to minimize the risk of breaking it aka the mistake @itronicsrepair is talking about.
By "caught" do you mean glued to the case? Mine was, and I cant tell how I could possibly have removed the screen without it breaking. Luckily my Ipod was already broken, but now its even more broke because of this guide.
Oops!!!…..I managed to break the little ribbon cable going to the hold switch…lots of very “colourful“ words aimed at myself are in my head now.
You're not alone, it's a very common mistake, I just did it too. This guide is poorly written. Step 8 should between Step 4 and Step 5 precisely to avoid this. Once the cable is broken, it's game over. There's no replacing it.
crwdns2935229:05crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
I followed all the directions carefully, using the correct tools, and viola...I now have a working iPod. Thanks iFixIt! :)
Be sure to use the smaller iPod opening tool and press it in FIRMLY in order to get enough leverage to get under the bezel and pry it off. Adhesive is very strong, so don't be afraid to use a little bit of force.
captcarl13 - crwdns2934203:0crwdne2934203:0
Tool broke before I could get the cover off !!! So I’m done before I even started !!
linda45p - crwdns2934203:0crwdne2934203:0
I have a Apple iPod Nano 4th gen(Green) and I only have 7 tech pieces to the iPod and I may/might have the small philips screws and I am not sure how to fix the iPod nano
Nick Davies - crwdns2934203:0crwdne2934203:0
I also had Problems to remove the bezel. The solution was to start with a very small screw driver from the hole of the switch. There I could lift it a bit and get the plastic tool in between. Than it was easy.
Michal Niewiadomski - crwdns2934203:0crwdne2934203:0
After replacing the battery, the old glue would lump up too thick, and also become too weak to fix the panel back to the outer case. I have scraped all the old glue off using a small flat head screw driver, and affixed a double sided adhesive tape cut into small strips, which was successful in both aspects.
diytradjazz - crwdns2934203:0crwdne2934203:0
TIP: Use a plastic tool and pull it out through the hold switch. This may break the top bezel, but this was the only way to get it off.
Caleb Murphy - crwdns2934203:0crwdne2934203:0
**** BEFORE YOU GO ANY FURTHER **** I totally ruined my Ipod and broke 4 parts including the LCD screen, so learn from my mistakes. This tutorial was VERY poorly written. Just keep an eye for any of my comments for each step and you should be fine.
happyoctopus - crwdns2934203:0crwdne2934203:0
