Battery not lasting long? Swap it out (requires soldering).
To aid in visualization, the two clips boxed in red are located closest to the headphone jack.
i don't know what genoration my ipod is...but it looks exactly like that on and it doesnt have the clips......what do i do?
https://www.ifixit.com/info/ID-your-iPod
Try that first to find what you have
Given the inherited risks of damaging the components, it would also be important to mention that the area where there are no clips is where the flat cable to the screen resides. So NO deep sticking tools in that area. It’s attractive to do because at that right side the back panel is intruded the easiest way - but dont do it.
if you want to travel down this fearsome road: This picture is the back cover lying down. The side towards the lower right corner is where the ports are. The three yellow clips down the side are on the same side as the lock switch. Plastic tools might be doable, but I worked with the "steel knife" from the ifixit toolkit, and some plastic prying tools to keep things open.
try this (for a change Apple actually helps): https://support.apple.com/en-gb/103823
Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, above the dock connector. The tool's edge should point toward the rear panel to prevent any accidental scratching of the anodized aluminum front case.
I don't have a gap big enough to put anything in it what do I do?
Insert a small iPod opening tool into the seam on the headphone jack side of the Nano, with the edge of the tool pointing toward the rear panel.
Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the the two tabs attached to the rear case, pushing the clips toward the center of the Nano until both have been freed.
the tool i bought because you suggested it to me got inevitably broken like it was butter made, thanks
This is virtually impossible! I have already cut myself when the stupid tool slipped trying to push in on the clips. Why on earth would anyone design something to impossible to open when they know the battery would need to be replaced at some point?
Forget the iFixit plastic tools. You need to use steel on steel. I used a heavy duty engravers knife I happened to have, to get it started. Then, a fine chisel and jeweler’s screwdrivers and LOTS of force to pry it off. I messed up the aluminum front case a bit, but I cleaned that up with sandpaper. The back case was bent a bit, but I straightened that, and after replacing the battery I fastened it back on with black electricians tape. It looks quite well, and good enough for me. I will cancel my order for a replacement back. Joe M 2/3/2018
Garbage tutorial, this step was probably scribbled down in 2 minutes off the top of someone’s head for real.
i never needed the large tool i just needed i little flat head screwdriver
Repeat the same procedure listed in the previous step to free the three clips along the hold switch side of the Nano.
Insert an iPod opening tool into the gap near the top left corner of the Nano and work to free the three clips along the top edge of the rear panel.
After ensuring all tabs are free, separate the two halves of the iPod.
The rear panel is now free from the iPod.
thanks you for help
i gotta say this is some of the worst prying I’ve ever done on a delicate electronic piece. Even with three sides off, that last top wouldn’t budge. I had to ram a thin alumninum tool in there and bend the top lip and it still wouldn’t move.
With the rear case removed, the back side of your Nano should now look like this.
At this stage an alternative (and more simple) procedure is to cut the battery wires between the battery and the logic board (one at a time to avoid shorts), remove the old battery, fit the new battery, strip and prepare the ends of the old cut wires, then solder the new battery to these wires again being careful not to short connections. Then sleeve or encapsulate these soldered joints (wax or blu tack will do). This makes it an easier and quicker job.
Sounds a much better idea to me.
I was just given some old parts in a box. Scored a decent router, laptop power supply and 2 ipods. Unfortunately, the newer one has half it's power connector snapped off and the other (4GB/A1236), I successfully reset via iTunes but it doesn't hold a charge! %#*@. I might just scout for an old speaker dock at a garage sale or such and put it in the bathroom or something.
Remove the following six screws:
One 1.8 mm Phillips.
Three 1.9 mm Phillips.
One 2.4 mm Phillips.
One 2.6 mm Phillips.
If your headphone jack isn't working, note that it is possible to replace just the headphone jack here:
There are just 4 soldering points that need to be loosened, and then you can put on the new one.
One 2.6 mm Phillips. The colour of this screw isn´t blue in the picture, it´s green.
I was able to remove the back cover using two think plastic guitar picks and my red cross donor card
I read some steps further back and it was recommended to NOT remove all the screws and the boards indicated in the following steps, but to go directly to replace the battery. It is no more difficult to go directly to cut the battery leads, or unsolder them. I tried to splice the new battery wires to the cut leads from the board, but it was hard working with the fine wire. I ended up clearing the top of the three battery solder-through holes, but I did not clear the holes. I soldered the battery leads directly to the top of the small round solder dots…first the white, then the black, and finally the red. I fastened the battery in-place with a piece of two-sided carpet tape. I straightened up the back and taped into place with black electricians tape. It is very delicate work, and not for a beginner…I repair family jewelry, which is valuable practice. Joe M 2/3/2018
Using a spudger, flip up the brown click wheel ribbon cable retaining clip.
Use the tip of a spudger to slide the click wheel ribbon cable out of its socket.
Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected). Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
When reassembling the logic board into the case, watch out for the tiny nose of the audio jack that's facing towards the center of the device. This nose has to be inserted first, then the rest of the audio jack followed by the logic board itself.
Use a spudger to flip up the display ribbon cable retaining clip.
Slide the display ribbon cable out of its socket.
Before proceeding, remove the metal EMI finger shown by pulling it away from the adhesive on the logic board.
I broke the EMI finger...is there someplace I can get a replacement??
Before de-soldering the battery cables, you must remove a small amount of black rubbery adhesive securing them to the logic board.
Push the tip of a spudger beneath the rubber adhesive and toward the battery to free it from the surface of the logic board.
Start freeing the adhesive from around one of the outer leads, then free it from the two gaps between leads, and finally push the spudger along the back side of the leads to completely remove it from the logic board/battery leads.
It’s actually much easier to remove the rubber adhesive if the battery is taken out and laid upside down.
The battery leads, now free of adhesive, should look like this.
be nice to know what adhesive to use to replace it after the new battery has been added.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Begin by heating the exposed end of the white battery lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
When you clamp the logic board in a small vice for electronic work, the battery hangs down and with the soldering iron in one hand it’s easy to pull the leads with the tweezers. For anyone with soldering experience this soldering is actually easy to do as long as you have the right soldering tool: sharp point, low wattage.
De-solder the remaining leads, following the procedure illustrated in the previous step.
All leads should now be de-soldered and disconnected from the logic board.
Using a spudger, pry the battery up from the adhesive holding it to the battery shield.
Start prying at the upper right corner of the battery and work your way around the perimeter until the battery has lifted enough to grab it with your fingers.
Remove the battery from the battery shield.
To open the solder holes, straighten out a staple and push it against the solder blocking the hole while simultaneously heating the same solder pad from the other side of the logic board.
In the shopping list of this page is the ‘desoldering braid’ which, if done quickly, is the easy way of taking the solder out.
I found that using a safety pin worked much better for me than using a staple. I was able to grab it better and get more force to push the solder through
This step should be delete. My ipad nano is useless because of this step!!
While a safety pain is recommended, I had trouble finding one that is small enough - a sewing needle did the trick though. Definitely recommend getting the hole free first.
Place the new battery in the metal battery tray, sticking it down to the adhesive.
Using a pair of tweezers, insert the stripped ends of the battery leads into their respective holes.
Insert the black lead into the rightmost hole.
Insert the red lead into the center hole.
Insert the white lead into the leftmost hole.
Solder the connection by momentarily placing the tip of the soldering iron against the connection, pressing solder into the connection (melting it), and quickly removing both the solder and the tip of the soldering iron from the connection. The solder should flow around the new battery lead, solidly connecting it to the pad on the logic board.
Solder the other two battery leads in the same fashion, taking special care not to bridge any of the connections together with solder.
crwdns2935229:0127crwdne2935229:0
crwdns2947412:021crwdne2947412:0
I have one suggestion about replacing the back cover after you are all done (If you did not purchase a new replacement cover). I noticed that in the process of removing the back cover, the metal clips get bent up. This causes the cover to be very loose when you replace it (this is the "considerable damage" I presume the article talks about. In order to get a tight fit, you must press down the clips very gently. One of the tack welds came off of mine, and I had to remove one of the metal tabs because it was useless, so be careful. Anyway, keep this in mind and you won't have to buy a new back cover. Thanks for the article, it really helped!
definitely get the back cover
This is NO EASY TASK. Much HARDER than the steps shown here. There is no way in !@#$ the plastic tool will separate the case...but I am sure someone will say there is.
Not I though.
I will be purchasing the back case now since it is obvious to me after receiving the replacement battery in the mail that I am going to butcher this thing up and the clips.
Peace.
I totally agree, the plastic tool broke the tangs right away. I had to use a small flat blade jewelers screwdriver to pry around. And yes, I bought a new cover
Bud -
I successfully opened the ipod with a walmart brand set that contained a large and small plastic tool. You gotta work it.
quick tip for opening the case, I found guitar picks worked nicely alongside a metal butter knife to pry the clips open. Got the case open within 5 minutes. Would definitely recommend getting a replacement back plate as mine has become slightly bent from the removal.
This is a great guide, expertly written for anyone to follow
Must have a magnifying glass or microscopic vision to solder the leads
Difficulty: Very difficult I agree whole heartedly.
There is no *(#$ing way the flimsy plastic tools provided could open the tightly assembled iPod case!!!! Don't bother to buy them as they are not sharp enough to separate the case and one even broke after being inserted between the two case halves, leaving its broken pieces between the two case halves. I had to use Xacto knives, utility knives, and jewelers screwdrivers to work the case apart and release the clips. (The instructions here were a GREAT HELP!) Have not yet bought a new cover as first I will try straightening out the old cover and its clips. Or that failing, I am hoping I can epoxy the whole thing back together and this will be the last battery replacement.
Removing the back is by far the hardest part of this process.
After this stage an alternative (and more simple) procedure is to cut the battery wires between the battery and the logic board (one at a time to avoid shorts), remove the old battery, fit the new battery, strip and prepare the ends of the old cut wires, then solder the new battery to these wires again being careful not to short connections. Then sleeve or encapsulate these soldered joints ( wax or blu tack will do).
NOTE: Don’t drink half a pot of coffee and two RedBulls before starting this!!! I had the leads for the battery in-and-out of the holes 22 times in three seconds!! Wow!! Other than my stupidity….I was able to complete this in about 45 minutes.
After the replacement the display only shows two green lines and a black display ? Whats wrong ?
I’m not at all good with repairing technology. I have two iPod 3 nanos that simply need new batteries. Could anyone repair them for a good price, or buy them if they’d like?
I was thinking i could never do this but I did !!! You will HAVE to order a new back it gets bent up while opening. i had to use a razor blade to get in between the front and back THEN i used a plastic wedge to get it open it. Its definitely possible to do. just have to take your time and RELAX..
Using a thin stainless spudger like the iSesamo press straight down at clip points to release them first before using the plastic spudgers to pry case off.
Excellent instructions. Best I have seen for iPod or iPhone. Would agree you must have some experience soldering small electrical components. I would recommend you purchase a de-soldering bulb instead of using a staple to clear holes of the battery leads on the circuit board.
I gotta say, yes, this was pretty darn difficult. The plastic tools were useful, but truthfully, I was able to open the back better with the 'flat-blade' screwdriver than anything wide. The plastic tool was good to open the seam at the charge port.
I think my iPod must be a refurb 'cause the 'black rubbery adhesive' around the battery wires was already mostly gone. So this must be it's 3rd battery!
If you take it very slow, take deep breaths occasionally, it'll work.
I managed to do this. But my iPod is now giving 2 beeps with a white screen. iTunes sees it though, and restore/sync works. I can even hear the clickwheel working. There is just no image on the screen. I guess screen might be ok, since backlight is working? I have tried all force reset tricks there are. Does anybody have any ideas? Thanks!
that screen is bad, the two beeps means the LCD is damaged. I have the same issue, replacing the screen worked for me.
the ipod nano 3g is so hard to work on
I need some help with trouble shooting, the unit use to be recognized in iTunes, screen lit up to the menu. Once I popped off the back using a dental tool to open a gap and then iPod opening tool and the thing that looks like a guitar pick. After getting the back off with little to no bends to the clips, I plugged it into the computer. I got a white flashing screen, and iTunes didn't recognized it. If I plugged it straight to a power source the screen stayed lit followed by two beeps. What on Earth did I do just getting the back off, or is this normal for battery failure ?
Since I really love my Nano 3, I decided to make a good one out of two defective ones. One had a defective battery and display, and the other kept resetting. The hardest part was opening the lid. But I was able to salvage the Nano and one of the lids.
I found removing the back to be very difficult and had to use a mini screwdriver to complete it. While removing the back to replace the clickwheel, I not only destroyed the back, I inadvertently mangled the video cable and so I then had to replace that too.
gruntso - crwdns2934203:0crwdne2934203:0
