iPod Nano 2nd Generation Display Replacement
  1. iPod Nano 2nd Generation Display Replacement, Case Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
    I dipped my (metal) pry tool in 91% isopropyl alcohol, as dripping alcohol in risks it dripping into the screen, then carefully sliding my pry tool in (pulling it slightly apart with my fingernail to avoid scratching), the adhesive came right off! I suggest using a new, smooth pry tool for this to minimize scratches on the metal.
    Emilien Sahli - crwdns2934203:0crwdne2934203:0
  3. iPod Nano 2nd Generation Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When removing the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel.
    • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
    I tried using a heat gun to soften the glue, but it ended up melting the white plastic part.
    gordonhamachi - crwdns2934203:0crwdne2934203:0
    I used an Avid Power heat gun at setting 3 heat and 2 fan and did not melt it. I pointed it at the metal case not the plastic thanks to tip above and kept my hand wrapped around it so I could tell how hot it was getting. If it was too hot to keep my hand there then I deemed it would be too hot for the plastic. That seemed to do the trick and loosen the adhesive just a little bit to help with extraction. Thanks gordon.
    N. Watson - crwdns2934203:0crwdne2934203:0
    I tried to get the bottom off but it would not budge I was not going to use a adhesive gun for safety what else should I try?
    Ruth Anne Sutton - crwdns2934203:0crwdne2934203:0
    I highly suggest using a sewing needle to remove any adhesive/glue from ALL of the screws before you try to remove them. And I also noticed that the set of phillips screwdrivers I used were not true to their size. I had a lot of fun doing this project
    Robert Tidwell - crwdns2934203:0crwdne2934203:0
  4. iPod Nano 2nd Generation Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #000 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
    On the iPod I worked on, #000 Phillips was the correct bit. Not #00.
    Eric - crwdns2934203:0crwdne2934203:0
    my small screw is completely stripped, what can I do?
    wittyahole - - crwdns2934203:0crwdne2934203:0
    that screw on the right sucks
    Ethan Elliott - crwdns2934203:0crwdne2934203:0
  5. iPod Nano 2nd Generation Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
    I used electrical or beading tweezers that were in my kit to remove headphone jack, seemed to work well also.
  6. iPod Nano 2nd Generation Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
  7. iPod Nano 2nd Generation Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack. Be careful, this screw is easily stripped.
    I logged this as a success, but I actually wound up stripping the screw on this step (I printed out earlier instructions that didn't have the warning). Reassembled it without said screw and I'm hoping for the best!
    anja - crwdns2934203:0crwdne2934203:0
    The screw on this step also stripped when I was following this tutorial, despite being very careful and taking the time for everything. This really happens _REALLY_ easily!
    I too reassembled the iPod without this particular screw. So far I've noticed no side-effects from this.
    Ultimately I was able to complete the whole guide and repair the Nano succesfully! :-D
    wil - crwdns2934203:0crwdne2934203:0
    i have also stripped this screw in this step. can i change the display without removing this screw? any help is greatly appreciated
    Lori Baldridge - crwdns2934203:0crwdne2934203:0
    I used a Phillips #000. No issues with the screws.
    JPagan - crwdns2934203:0crwdne2934203:0
    Also used #000 on all screws around bevels based on comments with success, thanks peeps!
    I stripped my screw on this step, i did everything method from google. But stuck, how can i solve it?
    Rakai - crwdns2934203:0crwdne2934203:0
    I agree. You want to use a Philips #000 here.
    Sam Dissanayake - crwdns2934203:0crwdne2934203:0
    I tried using a Phillips #00 and almost stripped it, but I got it out with a 1mm flathead (all of my other Phillips drivers were too large)
    David Harrell - crwdns2934203:0crwdne2934203:0
    the 1mm flathead trick worked for me
    Frontesque -
    i personally pulled the metal tab up a bit to use as a "holder" for the screw, then dropped it in with tweezers and screwed in with a non magnetic #000 and worked fine. this is a hellish experience though
    pesukarhu - crwdns2934203:0crwdne2934203:0
  8. iPod Nano 2nd Generation Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom bezel bracket out of the iPod.
  9. iPod Nano 2nd Generation Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #00 screws from the top of the iPod.
    Had to pick out resin with dentist tool to enable Philips driver to engage screw heads.
    Need to be very slow and careful with sharp end of dentist pick.
    afdelaurier - crwdns2934203:0crwdne2934203:0
  10. iPod Nano 2nd Generation Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The highlighted connector attaches the click wheel and headphone jack to the logic board. This cable must be disconnected from the logic board before continuing.
  11. iPod Nano 2nd Generation Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
    • Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
    When reassembling, the jack connector cable broke :'( iPod woking fine, with a new battery.... but no more sound. Grrrr
    TheRV - crwdns2934203:0crwdne2934203:0
  12. iPod Nano 2nd Generation Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to push the logic board through the iPod out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
    The headphone ribbon and the click wheel is on the top side of the cover, so be sure to apply force toward the down side to avoid scratching the click wheel's PCB.
    [deleted] - crwdns2934203:0crwdne2934203:0
    Before pushing I carefully used the spudger to move the top bezel (with the hold switch) out of the case first. Be careful, it’s got a tiny ribbon cable. But getting that out first made the logic board slide out relatively easily.
    jack.jansen - crwdns2934203:0crwdne2934203:0
    I really appreciate that tip! Couldn’t get mine out until I did that and it slid right out
    Timothy -
    If you have a swollen battery, as I did, it was not possible to remove logic board. My case was visibly expanded near the top making everything inside locked in position. I did the disassembly before any part purchases. If I got to the point where everything came apart nicely, I'd invest in the parts. Thank you ifixit.com for the comprehensive instructions and parts for this procedure.
    armcomdes - crwdns2934203:0crwdne2934203:0
    @armcomdes - well done! I wish i’d read your insight before ordering my replacement battery. My nano 2g battery is swollen, and only a sledgehammer could move any part that it now locks in place. So long, nano. I’ll try to return that sealed battery.
    Your insight should be at the top of all related nano pages: swollen battery? iChuckit is your only real option
    dantegd - crwdns2934203:0crwdne2934203:0
    I'm another victim of the swollen battery. Impossible to slide it out.
    Ronaldo Sugii - crwdns2934203:0crwdne2934203:0
    I've also had a swollen battery, but I was still abe to remove the logic board. After reading a bit online I discovered that I could make a very small hole in the center where the battery was exposed (it's at the top) so all the gas comes out. As long as you battery doesn't have a charge/has very little charge it should be fine. If you do poke a hole in your battery do it outside so no toxic fumes go in your lungs. When you puncture the battery you should hear a small amount of air escape (do NOT breath it in, but if you do it just smells like Sharpie) and the board should slide out like it normally does. Tape off the hole to prevent any more exposure to air or to trap the remaining fumes. It usually works, many people have done this without a problem and it's relatively safe for any iPod like this one.
    Oven - crwdns2934203:0crwdne2934203:0
  13. iPod Nano 2nd Generation Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When removing the logic board, place the tip of the spudger into the hole where you removed the screw and gently push it out. The crevice will keep it in place and decrease the chance of you damaging your board.
    My battery swelled and it was not possible to push out. Looks like I cracked the screen trying to free it up inside the case.
    SEAN Tanton - crwdns2934203:0crwdne2934203:0
    It is possible to remove a swollen battery although I think the correct term is definitely birth a swollen battery, as I just did 1 successfully and 1 unsuccessfully to the rest of the ipod, but still removed! If the battery is swollen, in most cases the screen may already be cracked or will get that way in order to get it out. Very poor design to retrieve Li-ion batteries for recycling. The battery that I was successful in getting out without damage was actually much more swollen than the other one but I learned from the 1st 1. I used a carpentry nail set so I did not put the tip inside the hole but on that piece of metal, which is quite strong. I put a piece of paper over the headphone connection to add some protection in case my nail set slid off while pushing. It took at least an hour or more, probably more but I had to take lots of breaks. Most of the time seemingly not budging it at all. My hand hurts now where I was gripping the ipod.
    N. Watson -
    Cont.—-I would love to make my own pictorial about it because I had to push on it in such a way that I could still use my headlamp to see what I was doing and control where the nail set was pushing and not let it slip out of place. Before I started pushing I also used 1 of my blue plastic triangles to wedge some coconut oil down both the battery side and screen side. I really do think that helped a lot and may have even been a key factor so if anybody has a more appropriate lubricant for this type of electronics, I am open for suggestions. I wouldnt want to do it again but it was very beneficial to learning about how much force it can take and discovering some other tools that worked better in that situation. Also taking apart an ipod that didnt have a battery issue was so easy, I feel like a master now, lol.
    my ipod is old and the screen is white (it was my moms). also can you sum this down im olny 10
    Danielle Gatewood - crwdns2934203:0crwdne2934203:0
    It just means he wants you to use whatever tool you're using and push the rest of the iPod out via pushing through that hole, good luck!
    Finn Brandt -
  14. iPod Nano 2nd Generation Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely remove the display and logic board from the metal casing.
    • When reassembling, ensure that the battery is well seated. If the fit is too tight, the edge of the display will score the inside of the screen window.
    When sliding back the logic board, watch out not to put too much stress on the side with the screen and the window, cause it may lead to annoying stripes on your window
    Jasper Jonkman - crwdns2934203:0crwdne2934203:0
    reassembly : use a small dry paint brush to remove dust and crime from display screen to avoid spots .
    On my nano, step 13 there is no screw on the yellow indicated spot, instead there is a screw deep in the housing below the headphone connector on the side
    Grit - crwdns2934203:0crwdne2934203:0
  15. iPod Nano 2nd Generation Display Replacement, Display: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to gently pry the battery up from the back of the display. Be careful not to put too much pressure on the display with your spudger.
  16. iPod Nano 2nd Generation Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to carefully pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display. By working from the inside of the display, you won't be able to accidentially pry up the clear plastic shielding.
  17. iPod Nano 2nd Generation Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel up the orange tape covering the display ribbon cable.
  18. iPod Nano 2nd Generation Display Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
    The plastic tab is very fragile. Mine is broken while repairing and now I do not know how to fix the ribbon - has anyone an idea???
    minne - crwdns2934203:0crwdne2934203:0
    iput in the screen but it shows up completly white. does the screen not work or did i put it in wrong somehow?
    psycho - crwdns2934203:0crwdne2934203:0
    is the second ipod to repair and is already making my life easier, a tip: when making repairs, I do it slowly, very slowly ...
    Fito Contreras - crwdns2934203:0crwdne2934203:0
    the above comment, do not use metal tools on ribbon.
    this would likely to tear ribbon or damage plastic tab, its good practice on any micro PC boards.
  19. iPod Nano 2nd Generation Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the display ribbon out of its connector and lift the display off of the logic board.
crwdns2935229:079crwdne2935229:0
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
crwdns2947412:011crwdne2947412:0
I also had a white screen. I emailed ifixit support and Brady Cabe suggested I reseat the display connector. That did it!
One hint: when you reverse the steps, you will have to reinstall the top bezel but you don't have to completely reassemble the bottom in order to test it. The earphone plug can be left hanging out (avoiding wear and tear on the fragile ribbon cable) as well as the metal brace and the three screws that hold everything together at the bottom - that reduces the possibility of stripping the screws. In my case, I did strip one of the bottom screws: the screen was broken in a car accident that also bent the case enough to make it hard to get to one of the teeny tiny screws. Even though I stripped that one, I was able to get it out by turning it with a (tiny) straight blade screwdriver: there was enough purchase for that even though the head of the screw does not have much material left.
nick - crwdns2934203:0crwdne2934203:0
I found that a 000 Phillips screwdriver worked FAR better than the 00 for all of the screws. Also, the one I repaired had a surprising amount of adhesive holding the battery down. The square end of the plastic spudger worked well to separate the battery from the rest of the internals allowing it to be rotated down and out of the way.
adamjacob - crwdns2934203:0crwdne2934203:0
No success here. I could not figure out how the black retainer worked in order to release the ribbon cable for the display. I ended up breaking it. I tried to put it back together anyway to see if there was sufficient contact to make it work, but evidently not. Oh well, a $50 lesson. One other tool that is needed here is a jeweler's magnifying glass. Magnified pics in these instructions would also be a benefit. Also, can someone tell me how you're supposed to get that one recessed screw back in place?
albertm - crwdns2934203:0crwdne2934203:0
Spit on the tip of my phillips screwdriver holds that tiny screw on until I can get it started in the hole
gordonhamachi -
I also had a white screen, followed the guide step by step, made the repair easy. I do agre with one of the other comments, a 000 phillips screwdriver worked way way better than the 00.
Shainal Nagar - crwdns2934203:0crwdne2934203:0
Hello,
My Wife iPod nano 2nd gen has a upside down screen plus lines ,would a new screen replacement fix this problem ,please can someone help
Ivor Harrison - crwdns2934203:0crwdne2934203:0
After replacing screen module, picture quality is course and unstable, also has a donut shaped blue ring on lower screen. Should perhaps used original apple parts, I strongly suspect this picture display is totally inferior quality flicked off into spare parts market.
Great experience replacing display, however I won't waste my time with this product again.
dangerous!!!
when I tried to push the logic board out of the case in step 12, the iPod exploded with a big initial flame followed by a thick heavy smoke shooting about a feet in one direction. Since I dropped it on my table where my computer was to save the table and equipment I pushed the smoking ipod on the floor burning my finger. Then with an oven mitten I throw it outside in the rain.
Ross Small - crwdns2934203:0crwdne2934203:0
My battery is swollen and won’t let me push out the logic board easily. The seat where the screw hole is mentioned to push the board through is completely gone. I put too much pressure and the seat for the screw is history. Anyone had this issue with swollen battery impeding the board from being pushed through?
le_grand - crwdns2934203:0crwdne2934203:0
I had this issue. My boy got absolutely wrecked :(
SpyChar -
Where to get the screen in the UK..?
Citizen - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 274
crwdns2942667:0crwdne2942667:0 96,201
