iPod Nano 1st Generation Display Replacement
iRobot
crwdns2944107:0crwdnd2944107:0iRobotcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 8, 2022crwdne2944111:0
crwdns2931287:030crwdne2931287:0 - crwdns2931291:02crwdne2931291:0
crwdns2937803:0crwdne2937803:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Replace a cracked or faulty display.
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
crwdns2944105:0crwdne2944105:0
  1. iPod Nano 1st Generation Display Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Turn on the notes and READ thru all the steps and the notes, especially the ones involving the ribbon cables.
    patjmccarthy - crwdns2934203:0crwdne2934203:0
  2. iPod Nano 1st Generation Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear panel is secured to the front case by eleven clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
    • To free the tabs, they must be pushed down and away from the iPod's case. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
  3. iPod Nano 1st Generation Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 1st Generation Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
    • Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
  4. iPod Nano 1st Generation Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a small iPod opening tool into the seam on the Hold button side of the iPod, with the edge of the tool pointing toward the rear panel.
  5. iPod Nano 1st Generation Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
    • Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the two tabs attached to the rear case, pushing the clips toward the center of the iPod until both have been freed.
  6. iPod Nano 1st Generation Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPod Nano 1st Generation Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPod Nano 1st Generation Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the same procedure listed in the previous step to free the five clips along the headphone jack side of the iPod.
  7. iPod Nano 1st Generation Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After ensuring all tabs are free, separate the two halves of the iPod.
    • The rear panel is now free from the iPod.
  8. iPod Nano 1st Generation Display Replacement, Battery & Logic Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any kapton tape over the screws, if necessary.
    • Remove the following 3 screws:
    • Two 3 mm Phillips screws near the dock connector.
    • One 4 mm Phillips screw along the edge of the logic board.
    • During reassembly, make sure to put back any tape or plastic you remove. This will prevent any shorts between the logic board and the rear panel. If your tape is unusable, kapton tape can be purchased online.
    Note that the 4mm screw has slightly wider pitch; you'll need this when putting the unit back together.
    daisystanton - crwdns2934203:0crwdne2934203:0
  9. iPod Nano 1st Generation Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel up the ground strap connecting the battery to the logic board.
    The battery ground strap does not have to be replaced. It works fine without it.
    henrymf - crwdns2934203:0crwdne2934203:0
  10. iPod Nano 1st Generation Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 1st Generation Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
    • Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
  11. iPod Nano 1st Generation Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the dock connector end of the logic board to ensure the logic board is free.
  12. iPod Nano 1st Generation Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
    • Make sure the logic board is lifted slightly above the white plastic notch on the battery side of the board. This notch prevents the board from sliding out in the next step.
    • Slide the logic board out of its holding brackets on the rear of the display.
    • The logic board is still connected to the iPod by two ribbon cables.
    During the disassembly of the board I somehow "delaminated" the display. The result was that the display (after the battery was changed and the device closed again) looked "cloudy". From some angle you couldn't see anything at all anymore. The solution was to heat up the hole device with a hair dryer and rest it on it's front side for about an hour. After that it looked absolutely perfect again. I am not sure whether the heating is really necessary (maybe just lying the ipod on the front side over night would have the same effect) and surely one should be careful to not overheat the device.
    Michael Benner - crwdns2934203:0crwdne2934203:0
  13. iPod Nano 1st Generation Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnecting the following two ribbon cables may be challenging. To prevent straining the cables or connectors, you can only separate the two halves of the iPod about 1/2 inch during the process.
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    Both ribbon cables were especially difficult to put back in. I can't say I succeeded in getting the nano to work again. If you can avoid detaching the cables, do it. If you're replacing the clickwheel, there's no way of avoiding it unfortunately.
    A little tip if you are replacing the screen: Reconnect this ribbon cable from the new screen BEFORE affixing the screen to the adhesive! It will make it much easier. Also be sure that the little black things are UP before trying to put the ribbon in, and make sure you put them DOWN before closing up! The black things on the receptacle "lock" the cable in place, so it is important that you have it STRAIGHT or it wont work. Good luck!
    Schovelbuddy - crwdns2934203:0crwdne2934203:0
  14. iPod Nano 1st Generation Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to slide the display ribbon out of its connector.
    Getting the display ribbon back in place is the most difficult maneuver in the whole fix. I actually broke the black plastic tab in half while trying to close it back down, (be very gentle with it!). Managed to put the broken half back in(tweezers and patience) and get that ribbon in and put it back down. This battery replacement was the most difficult/tedious repair I have ever done. Don't do it unless you are brave and stubborn.
    checheconleche - crwdns2934203:0crwdne2934203:0
    You can leave out this steps with disconnecting the two cables.
    Without disconnecting the two cables, one can separate the two pieces only 1/2 inch. This is enough to work carefully with the soldering iron and change the battery.
    It's a little bit difficult to work with the needle to open the three holes after removing the old battery - but you can do it.
    From the reading of the other notes it seems to me easier than to disconnect the two cables
    cguenther - crwdns2934203:0crwdne2934203:0
    Ribbon connectors and absolute ##&&%
    Dan Fitz - crwdns2934203:0crwdne2934203:0
  15. iPod Nano 1st Generation Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to flip up the black plastic tab holding the orange click wheel ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
  16. iPod Nano 1st Generation Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to slide the click wheel ribbon out of its connector.
    Don't do this unless you have to. Getting this ribbon back in is nearly impossible.
    crwdns2936937:0daisystantoncrwdne2936937:0
    Try using tweezers or medical clamps to reach in that tight spot. Use these tools to also connect the click wheel ribbon back to the logic board.
    Ryan - crwdns2934203:0crwdne2934203:0
    Stamp tweezers worked great for the ribbon cable! (Search eBay or Amazon, or your local hobby store.) This would be a useful tool for iFixIt to add to their inventory.
    Michael Lance -
    yeah i just finished puting in a brand new display but it only goes white - no text or anything just white.
    any tips?
    Mabrew - crwdns2934203:0crwdne2934203:0
    crwdns2936937:0Mabrewcrwdne2936937:0
    any tips?
    Did you ever fix it from white?
    katie - crwdns2934203:0crwdne2934203:0
    I wish I had read this thread before trying to remove the ribbons. I was unable to successfully restore these connections after installing the battery. Now my ipod, previously sick, is now dead.
    gregkotis - crwdns2934203:0crwdne2934203:0
  17. iPod Nano 1st Generation Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The logic board and battery are now free from the iPod.
  18. iPod Nano 1st Generation Display Replacement, Display: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to carefully pry up the adhesive holding down the edge of the display.
    • Be careful not to slide the spudger in too far to prevent scratching the display.
    Be careful when you are trying to remove a working display from the nano it came on (when replacing the faceplate as well). Because of the adhesive, too much force or pressure can cause the display to crack and cause the display to "bleed"... resulting in replacing that part if it was still good. Try using a hairdryer to gently warm the adhesive to then remove the display. Warning: Too much heat can also ruin the display or melt the front panel.
    Also watch out as the display is in two parts that can separate.
    patjmccarthy -
    I replace 2 displays, and they are still white,nothing else...maybe I damage
    SpeedManiac - crwdns2934203:0crwdne2934203:0
  19. iPod Nano 1st Generation Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on one corner of the display to separate the adhesive holding the display in place.
    • Lift up on the other corner of the display in the same manner.
  20. iPod Nano 1st Generation Display Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display up and out of the iPod.
  21. iPod Nano 1st Generation Display Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The display is now free from the iPod.
crwdns2935229:050crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
spegazione molto detagliata un complimento alla persona grazie
gianni - crwdns2934203:0crwdne2934203:0
Noice! I accidentally stepped on my screen (TBF, my cat was in the way) so I decided to consult the almighty iFixit! I did have a bit of trouble removing the screen, though, as I found the adhesive too strong to pull. Therefore, I used my spudger as a lever to pull it out.
As this was my first intro into the world of DIY electronics repairing (that is to say, one that didn't have me losing every piece to it), I'm ready to see what else can come at me!
(Also, be careful not to put any fingerprints on the inside of the screen. I nearly did that, but some toilet paper and some isopropyl fixed it up.)
GrayDolf - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 119
crwdns2942667:0crwdne2942667:0 41,191
