crwdns2937539:0crwdnd2937539:0crwdne2937539:0
Use this guide to remove all components from the rear case of your iPhone 7. This guide will show you how to remove speaker vents, button cables, and button covers so you can replace a dented or bent cover.
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Attach a suction cup to the lower half of the display assembly, just above the home button.
Pull up on the suction cup to create a small gap between the display assembly and the rear case.
Insert the flat end of a spudger into the gap.
Slide the spudger to the left along the lower edge of the iPhone.
Twist the spudger to widen the gap between the display and rear case.
Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
Insert the flat edge of a spudger into the bottom right corner of the device.
Twist the spudger to widen the gap between the display assembly and the rear case.
Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
Pull up on the suction cup to lift up the display and open the iPhone.
Pull up on the small nub on the suction cup to remove it from the front panel.
Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
crwdns2935267:0crwdne2935267:0Tri-point Y000 Screwdriver$5.99
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use the point of a spudger to lift the battery connector out of its socket on the logic board.
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
Disconnect the front panel sensor assembly connector from its socket on the logic board.
Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
One 3.2 mm screw
Remove the following three Phillips screws securing the speaker to the rear case:
Two 1.3 mm screws
One 2.0 mm screw
Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
Use tweezers to derout the antenna cables from their bracket on the logic board.
Use tweezers to remove the antenna cables from the clip on the speaker.
Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the iPhone.
Use the flat end of a spudger to disconnect the rear-facing camera connector.
Remove the following Phillips screws securing the rear camera bracket to the rear case:
One 1.3 mm screw
One 2.5 mm screw
Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
Use the flat end of a spudger to disconnect the upper cable connector.
Remove the four Phillips screws securing the Wi-Fi antenna:
Three 1.2 mm screws
One 1.7 mm screw
Remove the following Phillips screws:
One 1.3 mm screw
One 2.2 mm screw
crwdns2935267:0crwdne2935267:0Standoff Screwdriver for iPhones$5.49
Remove the 2.2 mm standoff screw from the grounding bracket.
Use tweezers to gently bend the logic board grounding bracket out of the way.
Use the point of a spudger to disconnect the lower cable connector.
Remove the following screws:
One 1.4 mm Phillips screw
Three 2.2 mm standoff screws
In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
Lift the battery connector end of the logic board and pull it up and out of the rear case.
Remove the 2.9 mm Phillips screw from the lightning connector.
Remove the spring contact from the lightning connector.
Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
Remove the two 1.3 mm Phillips screws from the rear case.
Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
Continue to slide the pick underneath the lightning connecter assembly.
Stop sliding the pick once it passes the battery.
Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
Stop sliding the pick when it reaches the lightning connector.
Gently pull the lightning connector out of its hole on the rear case.
Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
Remove the lightning connector assembly.
Use a plastic tool to scour any bits of adhesive residue from the rear case.
Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
Repeat the previous step for the second strip.
If you removed both adhesive strips successfully, skip the next step.
Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
Remove the battery from the rear case.
Two 1.9 mm screws securing the power button.
Three 2.3 mm screws securing the volume buttons.
Remove the following 1.3 mm Phillips screws:
One screw beside the rear-facing camera
One screw on the rear case
From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
This action will free the hold switch and gasket from the rear case.
Use a pair of tweezers to remove the rear-facing camera.
Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
Remove the antenna flex cable.
Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
Use the point of a spudger to gently unseat the flash module.
Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
Gently fold the power button module from the edge of the rear case.
Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
Continue to separate the adhesive by moving the blade towards the top of the phone.
Continue to move the blade of the halberd spudger underneath the power and volume control cable.
Slide the halberd spudger under the volume control portion of the button cable.
Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
Remove the power and volume control cable.
Pull the clip towards the bottom of the phone and lift up to free it from the bracket.
Push the lower end of the power button bracket up off of peg securing it.
Pull the bracket from the rear case.
Use the pointed end of a spudger to push the power button cover out of the rear case.
Remove the power button cover.
Pull the volume button clip towards the bottom of the phone to free it from the bracket.
Pull the clip towards the top of the phone to remove it.
Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
Rotate the spudger to pop the bracket off of the peg on the volume button.
Repeat the procedure to remove the second volume button bracket.
Use the pointed end of a spudger to push each of the volume button covers out of the rear case.
Remove the volume button covers.
Use the point of a spudger to push the left rubber speaker vent out of the rear case.
Remove the right rubber speaker vent from the rear case.
Remove the 1.5 mm Phillips screw securing the grounding bracket.
crwdns2935229:071crwdne2935229:0
crwdns2944067:010crwdne2944067:0
Great manual. I was successful in this repair but bought a rear case with small parts. Safes up a lot of work and time :)
Great Guide!
There are some components that may need to be transferred to your new case, which are not in this guide:
1 speaker screens
2 screen mounting catches
3 put the SIM card tray ejector pin back in BEFORE the logic board. I inserted it before mounting the logic board, otherwise the pin may fall out.
Hello everyone!
Has anyone had problems with reception, especially the 4G network, after replacing the body with a non-original one?
thank you and sorry for my terrible english!
Merci tres bon tutoriel tout c’est bien passé
HIW much cost to changing it
