iPhone 16 Pro LiDAR Sensor Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 16 Pro LiDAR Sensor Removal, Prepare the phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Prepare the phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro LiDAR Sensor Removal, Tape over any cracks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Tape over any cracks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro LiDAR Sensor Removal, Mark your opening picks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Mark your opening picks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Mark your opening picks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro LiDAR Sensor Removal, Remove the pentalobe screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Remove the pentalobe screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro LiDAR Sensor Removal, Disconnect the LiDAR sensor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Disconnect the LiDAR sensor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Disconnect the LiDAR sensor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the LiDAR sensor press connector.
  6. iPhone 16 Pro LiDAR Sensor Removal, Remove the LiDAR Sensor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal, Remove the LiDAR Sensor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws securing the LiDAR sensor:
    • One 1.7 mm‑long screw
    • One 3.0 mm‑long screw
  7. iPhone 16 Pro LiDAR Sensor Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro LiDAR Sensor Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or tweezers to lift and remove the LiDAR sensor.
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement LiDAR sensor using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
crwdns2935283:003/24/24crwdne2935283:0
20,481 crwdns2915208:0crwdne2915208:0
crwdns2935297:0115crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,989crwdne2935297:0
crwdns2942667:0crwdne2942667:0 57
