iPhone 16 5G mmWave Antenna Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 16 5G mmWave Antenna Removal, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 5G mmWave Antenna Removal, Tape over any cracks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Tape over any cracks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 5G mmWave Antenna Removal, Remove the pentalobe screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the pentalobe screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 5G mmWave Antenna Removal, Mark your opening picks: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Mark your opening picks: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Mark your opening picks: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  5. iPhone 16 5G mmWave Antenna Removal, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iOpener
    $14.99
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 5G mmWave Antenna Removal, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 5G mmWave Antenna Removal, Back glass information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  8. iPhone 16 5G mmWave Antenna Removal, Heat the right edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  9. iPhone 16 5G mmWave Antenna Removal, Separate the bottom right adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Separate the bottom right adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Separate the bottom right adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  10. iPhone 16 5G mmWave Antenna Removal, Heat the left edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  11. iPhone 16 5G mmWave Antenna Removal, Separate the left adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Separate the left adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Separate the left adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  12. iPhone 16 5G mmWave Antenna Removal, Heat the top edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  13. iPhone 16 5G mmWave Antenna Removal, Separate the top right adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Separate the top right adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Separate the top right adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  14. iPhone 16 5G mmWave Antenna Removal, Reposition the back glass: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Reposition the back glass: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Reposition the back glass: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  15. iPhone 16 5G mmWave Antenna Removal, Remove the middle connector cover screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the middle connector cover screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  16. iPhone 16 5G mmWave Antenna Removal, Remove the middle connector cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the middle connector cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the middle connector cover: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  17. iPhone 16 5G mmWave Antenna Removal, Disconnect the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Disconnect the battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  18. iPhone 16 5G mmWave Antenna Removal, Disconnect the wireless charging coil: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Disconnect the wireless charging coil: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  19. iPhone 16 5G mmWave Antenna Removal, Remove the back glass: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back glass off the frame and remove it.
  20. iPhone 16 5G mmWave Antenna Removal, Remove the top bracket screws: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the top bracket screws: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the four screws securing the top bracket:
    • One 3.5 mm-long Phillips screw
    • Two 1.4 mm-long Phillips screw
    • One 1.0 mm-long tri-point Y000 screw
  21. iPhone 16 5G mmWave Antenna Removal, Remove the top bracket: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the top bracket: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the top bracket.
  22. iPhone 16 5G mmWave Antenna Removal, Disconnect the front camera: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Disconnect the front camera: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Disconnect the front camera: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the two front camera press connectors.
    • The second press connector is underneath the first.
  23. iPhone 16 5G mmWave Antenna Removal, Remove the front camera: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the front camera: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the front camera: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger between the top edge of the front camera and the frame.
    • Lift the front camera out of the frame and remove it.
  24. iPhone 16 5G mmWave Antenna Removal, Disconnect the 5G mmWave antenna: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Disconnect the 5G mmWave antenna: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the 5G mmWave antenna press connector.
  25. iPhone 16 5G mmWave Antenna Removal, Remove the stretch release adhesive: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the stretch release adhesive: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the stretch release adhesive: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use angled tweezers to grip the black pull tab at the bottom right corner of the 5G mmWave antenna.
    • Press the antenna down with your free hand and use your tweezers to pull the stretch‑release adhesive strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the antenna.
    • To better grip the adhesive strip, you can twist it around the tip of the tweezers while you pull.
    • If the adhesive strip breaks off, try to retrieve it with your tweezers and continue pulling.
    • If you can't retrieve the strip, follow the next two steps for an alternate method. Otherwise, skip the next two steps.
  26. iPhone 16 5G mmWave Antenna Removal, Apply isopropyl alcohol: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Apply isopropyl alcohol: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Apply isopropyl alcohol: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a few drops of isopropyl alcohol (>90%) to the bottom edge of the 5G mmWave antenna.
    • Lift the bottom edge of the phone to let the isopropyl alcohol flow under the antenna.
    • Wait one minute for the adhesive to loosen.
  27. iPhone 16 5G mmWave Antenna Removal, Pry up the antenna: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Pry up the antenna: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the top left edge of the 5G mmWave antenna, near the front camera cutout.
    • Pry up the antenna to separate the adhesive.
  28. iPhone 16 5G mmWave Antenna Removal, Remove the 5G mmWave antenna: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 5G mmWave Antenna Removal, Remove the 5G mmWave antenna: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the 5G mmWave antenna off the earpiece speaker and remove it.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
174,043 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,823crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 332
