iPad Display Assembly 3 Pc. Adhesive Application
  1. iPad Display Assembly 3 Pc. Adhesive Application, iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application, iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue.
    • Use tweezers to pull up sections of tape residue.
    • Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive.
    • Remove the residue by wiping in one direction to prevent smearing.
    • Do not scrape with a metal tool, or you will scratch the display assembly's surface.
  2. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay out the replacement adhesive strips around the display assembly so that they correspond to the correct sides.
  3. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Each adhesive strip is encased in four layers of plastic—three on top and one on the bottom.
    • Peel and remove the topmost plastic cling layer from the left adhesive strip.
    • Peel and remove the bottom plastic liner from the strip.
    • The top of the adhesive strip should still be covered by a colored plastic layer as well as a clear plastic stiffening layer.
    • The bottom of the adhesive strip should now be exposed and sticky.
  4. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If there are extra bits of adhesive on the strip that are not required for your particular model of iPad, remove them now.
  5. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the left adhesive strip to the left edge of the display assembly.
    • Beginning from one corner, lay the adhesive strip onto the display assembly and press the strip into place.
  6. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the process with the right adhesive strip.
    • Peel and remove the topmost cling layer from the strip.
    • Peel and remove the bottom liner layer from the strip.
    • Align the adhesive strip to the right edge of the display assembly.
    • Starting from one corner, lay the adhesive strip onto the display assembly and press in place.
  7. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the process for the top adhesive strip.
    • Peel and remove the bottom liner from the strip.
    • Align the strip to the top of the display assembly such that the straight adhesive line bridges the gap between the left and right strips.
    • Press the strip in place.
  8. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel and remove the clear plastic stiffening layer from all three adhesive strip sections.
    • The adhesive strips should still be covered by colored plastic liners.
  9. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue with the reassembly process until you are ready to seal the device.
  10. iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Display Assembly 3 Pc. Adhesive Application: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel and remove the three colored plastic liners to expose the adhesive.
    • Close the device and stack some heavy books on top of it for thirty minutes to help the new adhesive bond.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
crwdns2935229:062crwdne2935229:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
313 746 crwdns2915208:0crwdne2915208:0
crwdns2935297:0729crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023 768crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Thanks, I was able to fix my wife’s shattered digitizer screen on the iPad 6th gen with this guide!
Kevin Chatterton II - crwdns2934203:0crwdne2934203:0
I managed to get it done, but this was a personal nightmare for me and more difficult than replacing the battery in my ipad. There are too many instruction that say “remove plastic” and I have no idea which layer; there was nothing on the packaging to indicate which side was up or which side was the front and I ended up guessing the wrong direction because it “looked” right, but wasn’t. A simple sticker on the packaging indicating a direction would have removed all of the frustration. I only managed to figure it out by removing all of the plastic so that the sticky side of the adhesive was exposed and then I could finally see how it was supposed to fit and how I was supposed to press down with the other side of the plastic to push the adhesive side into the frame.
twizzlercraze72 - crwdns2934203:0crwdne2934203:0
Fixed a cracked iPad 4 mini screen; I agree with twizzlercraze72. Some kind of labeling would have saved so much peeling and re-sticking. I ended up with a gap next to my home button. An expensive lesson to learn.
CBrewington - crwdns2934203:0crwdne2934203:0
For me, actually replacing the battery wasn’t too bad, but I ended up using too much isopropyl to clean off the old glue, and it seeped under the display and ruined it. Wish Apple didn’t use so much glue. It massively impedes repairability, which is not very environmentally sound. My iPad was perfect apart from the battery - it’s now got a perfect battery but the iPad is ruined :-(
Alex Harness - crwdns2934203:0crwdne2934203:0
Same here :(. $50 repair just turned into $250!
Paul Manos -
crwdns2936751:024crwdne2936751:0 25
crwdns2936753:07crwdne2936753:0 201
crwdns2936753:030crwdne2936753:0 721
crwdns2942667:0crwdne2942667:0 52,568
