crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the RAM.
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
PC3-12800 2 GB RAM Chip$25.99
Spudger4.9
While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
Pull the RAM access door off the back of the iMac.
Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
Re-insert the RAM access door back into its place.
crwdns2935229:072crwdne2935229:0
crwdns2947412:014crwdne2947412:0
I just purchased RAM and this guide was very accurate. Thank you.
Nicole Hamilton - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi guys! I have to slot full with the basic amount of RAM (2 x 4 GB), can I install 2 x 8 GB in the other two slots available? I want to upgrade to 24 GB of RAM, but I don't know if there are any problem putting together 4 GB modules with 8 GB ones. I remember an old story about possible issues... Thanks for your replies! :-)
Franz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You should be fine with pairs of equal capacity. 2 X 4 GB and 2 X 8 GB
Usually best to install in pairs of similar sizes
P
mrmacfixit - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I just upgraded mine from 16GB to 32GB. The only problem with this guide is that it says the difficulty is moderate. What could be easier? It took me less than five minutes, and most of that was unplugging/replugging stuff before and after the actual RAM upgrade.
I used a screwdriver to push on the little button that opens the door, as I didn't have a spudger handy.
Jake Robb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great job, thanks
ventosa09 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
