iMac Intel 27" EMC 2639 Hinge spring caps Replacement
    • Firstly, you need to access the iMac's hinge. Find the appropriate disassembly guide for your iMac. I used iFixit's guide for the logic board. You don't need to follow it exactly.
    • Speakers don't need to be removed. You can simply loosen them and carefully move them out of the way, in order to remove the necessary components.
    • The hard drive, logic board, power supply and fan need to be removed.
    M5 flat washers can be hard to source. I found SAE #10 brass flat washers (a Home Depot item) are the perfect fit. They have a smaller o.d. than #10 steel flat washers.
    py - crwdns2934203:0crwdne2934203:0
  1. iMac Intel 27" EMC 2639 Hinge spring caps Replacement, Remove broken caps: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 27" EMC 2639 Hinge spring caps Replacement, Remove broken caps: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the broken caps. I suggest that you replace them both, even if only one of them has broken off.
    • Take caution while unscrewing the cap's screw, since the spring is under tension. You don't want it flying to your face.
  2. iMac Intel 27" EMC 2639 Hinge spring caps Replacement, Make the new caps: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take an M5 washer and bend a small portion of it at a 90° angle. This will act as a hook that will hold the spring in place, preventing it from slipping.
  3. iMac Intel 27" EMC 2639 Hinge spring caps Replacement, Replace the caps: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 27" EMC 2639 Hinge spring caps Replacement, Replace the caps: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 27" EMC 2639 Hinge spring caps Replacement, Replace the caps: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is tricky and you will probably require assistance.
    • You need to bring the screen angle all the way down. This way you'll need to exert less force against the spring, while inserting the screw.
    • Pass the screw through the washer, making sure the bent portion is facing the straight end of the spring.
    • Slowly push the screw towards its threaded base. Mind the washer's orientation and be careful. If you slip, the spring can eject the screw and washer away.
    • Ensure that the screw is positioned straight over the threaded base. You don't want it to start biting its way through. It's gonna ruin the threads and you'll end with a way bigger problem than you started with.
    • Slowly start turning the screw. It's gonna be fairly difficult. Don't stop pushing the screw while screwing, unless you are sure that you've got a couple of full turns .
    • Now you can release the pressure against the screw and simply keep screwing until the washer has successfully secured the spring. Don't over-tighten.
    Many thanks for this! I found getting the screws back in very tough, especially as I was working alone. In the end I fitted the screws and washers loosely (couple of turns) with the locating ‘hooks’ on the washers rotated 45 degrees ‘up’ from their final position, then forced the spring end under the washer, before finally rotating the washer round to its final position (using a pair of pliers) and tightening the screw. Also, in order to minimise tension on the springs, the screen needs to be pointing up (when viewing the computer as if you were using it), not down. And lastly, don’t be alarmed when the screen doesn’t stay down once you’ve fixed it - it requires the weight of all the other parts to balance properly and will work once the computer is fully reassembled.
    samusiskin - crwdns2934203:0crwdne2934203:0
    • Assemble all the components back in the computer and close it up.
    • You're done!
Sotiris Alexandridis
crwdns2935283:006/21/20crwdne2935283:0
295 crwdns2915208:0crwdne2915208:0
Brilliant solution from Sotiris Alexandridis! This is a critical fail on the part of Apple. I know no one with a 2013 machine without broken caps.
Great tutorial. This worked for me up until the final screws holding the springs, so I cheated.
Undo the 9 screws holding on the stand. Remove stand. Then undo the 6 screws holding the bracket onto the back. Remove bracket. Now you can get a vise grip or similar and turn the inner end of the spring.
kenif - crwdns2934203:0crwdne2934203:0
Thank you very much for the tutorial, kenif comment sould be part of this. Thanks again
Aula Play - crwdns2934203:0crwdne2934203:0
I did it. Thank you for the idea. Cheap and sturdy now.
crus - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 9,148
