iMac Intel 27" EMC 2429 Hard Drive Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iMac Intel 27" EMC 2429 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 27" EMC 2429 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the SATA power and data cables from the hard drive by pulling them straight away from the hard drive.
    The CTO Apple SSD drive is located underneath the Optical Drive on the right. If you’re checking for it’s location, follow the steps to remove the Optical Drive instead, then you’ll find the SSD underneath it.
    Wizdom On Wheels - crwdns2934203:0crwdne2934203:0
  2. iMac Intel 27" EMC 2429 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 27" EMC 2429 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T10 Torx screws securing the hard drive to the iMac frame.
    • Slightly rotate the top edge of the hard drive away from the outer case.
    • Lift the hard drive off its two lower positioning pins and remove it from the outer case.
  3. iMac Intel 27" EMC 2429 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 27" EMC 2429 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T8 Torx screws securing the upper bracket to the hard drive.
    • Remove the upper bracket from the hard drive.
    • Remove the two T8 Torx pins from the other side of the hard drive.
    Screws on the hard drive are T9 for me.
    Sorak K. Laflamme - crwdns2934203:0crwdne2934203:0
  4. iMac Intel 27" EMC 2429 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel off the piece of EMI foam attached to the front of the hard drive.
    • Don't forget to transfer this to your new hard drive.
Phillip Takahashi
crwdns2935283:008/22/11crwdne2935283:0
87.396 crwdns2915208:0crwdne2915208:0
crwdns2935297:087crwdne2935297:0
Hallo habe einen i Mac von 2011 und dort war die HDD ausgebaut und eine SSD eingebaut. Habe jetzt alles soweit das ein Betriebssystem drauf ist und im Bootmenü erkannt wird. Er fährt aber nicht hoch. Apple Hardware Test sagt Temperatur Sensor Festplatte. Welches Kabel brauche ich da und haben sie ein solches?
MFG
Andreas
Andy Masloh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 613
