Air Conditioning Thermostat Replacement
crwdns2936025:03crwdne2936025:0 —
Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
