How to repair Einhell BT-JS 400E Jigsaw
crwdns2936025:01crwdne2936025:0 —
Shows general view of the jigsaw. The blue plastic casing needs to be split in half by undoing about 8 screws on the casing and two screws holing on the foot.
You may need to remove the paper advertising sticker to pull the two halves apart.
Pull apart gently as many items may fall out depending on how much old grease and wood dust sticks them to the casing.
Unscrew two bolts holding in the mains cable, then motor, switch, wiring, in fact everything can be pulled out of the casing.
Good idea to note or photograph the above procedure to ease reassembly.
