Makita Circular Saw HS7601J Flex Replacement
crwdns2936025:03crwdne2936025:0 —
Using a philips screwdriver, unscrew the screw on the live terminal (the brown wire), there should be a little brass piece below the screw (do not lose this piece).
Using a 3.5mm screwdriver, loosen the terminal screw on the white connector and remove the neutral wire (the blue wire).
