Rug Doctor Hinge Plate Rivet Replacement
crwdns2936025:01crwdne2936025:0 —
This step shows how to drill a rivet out.
Center a sharp 3/16" drill bit on the rivet head's indentation.
Drill at slow to medium speed while applying steady pressure.
Drill about 1/3" deep—enough to drill past the rivet head and into the shaft.
Use a center punch and mallet to tap the shaft away from the head. Remove the rivet head.
You may not be able to retrieve the rivet shaft. This is normal.
